Soo slow engaging and disengaging diff locks.
Asturias(Spain)-London(England)
Website
www.sybaris-expediciones.com
Hello.
My cruiser takes a life to engage and disengage rear and front diff locks. The central is ok, it engages in a seconds and it takes a little to disengage but that's ok.
The rear is the one that takes more, between 10 and 40 seconds to engage and about 10-20 to disengage, sometimes it helps if I slightly turn the steering weel, sometimes it doesn't.
Then the front takes from 0 seconds to 40 to engage and between 0 and 30 to disengage.
Is this normal?. It always took a little but I think not as much as now. What can I do to properly mantain the diff locks?. Does the diff oil has to do with it?. I changed it 22000 km ago (about 15000 miles).
Normal if they don't get much use. Recommendations here say go give them some exercise at least monthly. Turning the wheels slightly will help them engage an disengage as you've discovered.
Not 1 million percent positive, but here's my gut feeling:
Your lockers are not a fine spline that can align and engage/disengage easily. Yours have 5 splines, consequently your tires could have to spin up to 1/5th turn before alignment is achieved. But then at the point of alignment you could not have pressure on them or they would not engage/disengage. Perhaps the long lag time on yours is because you are not achieving alignment and no pressure at the same time, thus you should be doing more short rocking of the vehicle (small partial tire rotations)????? I don't know if this makes sence, or if I am way out in left field somewhere?????
Mine were VERY slow too until---I EXERCISED them. Regular and frequent use was the trick to get mine to engage quickly (3-5 seconds most of the time). Hope that's the issue with yours because it's a simple (and fun) fix!
Good luck,
Jwp
This is only true on the rear. The front locking cog is a fine spline, it's pretty much exactly like the Taco/4Runner TRD e-locker, just a mirror image.
Use it or lose it. Mine were pretty slow when I picked her up from the PO. I ended up pulling them apart and cleaning them. Now they get frequent use and work just fine.
We just bought a '95 w/ 140k on the clock. The lockers were not working, so the PO had to fix the issue before the deal. He got the front working via exercise, but had to replace the rear actuator to the tune of $800 or so. The rear, w/ the brand new actuator is very slow to engage and you have to drive several yards to get it to lock. I am wondering if driving very slowly, on foot on brake, on on gas, will help alignment and get it to engage more quickly. I'll test that sometime in the near future. FWIW, the front locks pretty quick now, but certainly not sitting still.
:beer: Ramon
Thank you all.
It seems like exercise is what they need, but they have only been unused for three months now.
I remember that the last time I used them I was stuck in a 3 ft mud hole that a tractor had to pull me from and I didn't used them again after yesterday. May the mud and water have altered the motors?. Anyway, I will try to exercise them and give you reports.
Yep... Exercise. Mine worked one fine snow day great..... by our next club meeting 2mo later, no locky. (just the center). Now I try to engage it whenever I get the chance. Zero issue so far.
Excercise and fresh fluids helps. I had the same issue when I bought mine and worked them weekly. I had a sudden stuck not long after and they worked immeadiately. Saved my axle!
Sometimes they still take a while but I have learned to antisipate issues and get them locked before I need them.
:beer: Ramon
The only way that it will lock when stopped, is in the off chance of the splines being lined up. In use, when you actually need lockers it isn't an issue. To get them to lock, you need differential action (one tire turning faster than the other) to lineup the splines. When you need a locker it's because of excessive differential action (one tire on the axle slipping) so locking isn't an issue.
On the trail, I ignore the silly lights, don't care if they are on solid or flashing. Approach the obstacle, click the switch, if the locker is needed it will lock.
My favorite way to test is to jack up the axle in question, click the switch and turn a tire. If the actuator working correctly, it should lock right up.
That just makes too much sense. LOL. I really appreciate that simple, yet thorough explanation. I will try the recommended test just for s***s and giggles.
:beer: R
I have found the same. Turn the switch when you anticipate that you need them, once you have some wheel spin they click straight in. Rear one in particular can tae quite a while to lcok up but always seems to be immediate once their is wheel spin.
Great!
That explains why they worked everytime I needed them, but they didn't last time. Other times I engaged them cause I needed them, last time I was just bored and said, "let's check the lockers" in a slippery but flat surface with enough grip.
May this effect be done on purpose by Toyota Engineers?. To protect the axles from idiots like me that engage the diff locks when it's not needed.
Great!
YUP!!!!!!!!!!!!!!
