Something strange today, need help.
Yuma, Az
Turned key to off position and removed but it kept running. Like the timing was too far advanced or detonation. Today was 95 degrees out and the engine was running about 193 when I shut it down. My hand throttle kinda sticks around 1100 RPM give or take. When it kept running in off I turned the key to on and it ran like normal. No starter involved... Why?
Even after I drove it? I pulled into a parking lot and that's where it happened, when I went to shut it down. When I got home I noticed it runs rough at around 1k RPM.
That can happen when the starter contacts stick.
ditto on this - happened to me a few months back - replaced the starter contacts and problem gone.
Probs an idea to rebuild your starter - it's simple and cheap - takes about 2 hrs start to finish......
although with me my starter continuously tried to start the engine even with key removed - like they were fighting each other - if this happens pull the battery out of the equation - this is not good and I was told is can be a fire hazard.....
Sounds me me maybe like a worn key cylinder and pulling the key out before it was turned all the way off. Lots of old cars can have this happen.
Just remembered one time my starter solenoid stuck in the on position in the winter and continued cranking the engine while I stood there with keys in hand. Disconnected the battery. Replaced the starter solenoid.
At normal RPM, my scan gauge timing says 4 so that's good. The only thing I can think of is it was detonating. It's like it was running on 2 or 3 cylinders.
Running on is quite a feat for a fuel injected engine. For this to happen you either have leaking injectors or you ECU is still powered up. The fact that it runs on a couple of cylinders, maybe leaking injectors. Does it die out eventually when the fuel pressure in the line drops? Or is the fuel pump still running as well.
As a side note, we had an engine that would not shut off due to an incorrect 3rd brake light bulb installed! Benz, not Toyota though
This whole problem is new. I just installed dual Batts with a blue sea ACR and switch and a hand throttle. The hand throttle wasn't adjusted properly and it kept the rpms just over 1000. Leaking injectors could explain something but since I adjusted the hand throttle it hasnt don't it again... As far as if it dies out when the psi drops I don't know. When it did it I waited a couple seconds and put the key in the on position. It then ran on all six like nothing happened. Other the the hand throttle keeping the rpms up...
Lol, not really. That's why I'm asking. I'll be checking deeper into it when I have more time. I'm going to be looking into the service manual on everything that's mentioned here.
I'll ask the question not asked: Is it a diesel?
You didn't identify Make, Model, and Year.
