Some wiring issues
Abbotsford,BC, Canada
Website
dubmatic.spaces.msn.com
Ok , I have a '78 fj40 Lights were all working except for the brake lights dont come on when you touch the brakes, and when you turn the left signal light on it stays solid doesnt flash. bulbs are good just replaced them all. When you turn the right signal on it flashes. Hazard worked for when you turned it on all the lights flashed on and off. Yesterday I went to try the hazard and nothing happened it stoped working and now the high beam indicator on the cluster doesnt show its lit. Also I unplugged the rear tail light harness plug to check some wires hooked it back up and now the pass rear brake light stays lit even with every thing turned off and the keys out...... its starting to drive me insane......
No the tub Is full metal all origional. the ground wire did look sketchy to me I was going to replace the grounds tommorrow and get a better ground strap from the Battery and change the connectors on the Batt. Thanks
It sounds like you have multiple coincidental problems. Some fall into the general class of bad connections somewhere between the battery and the ground. The light that stays on sounds like inappropriate wiring.
Sorry I can't be more helpful, but maybe if you describe the problem in more detail and what you have done to investigate it.
Check the fuse block or even get a new one from Toyota. On a 79 and newer they are not removeable but on your 78 it should be. They corrode inside and start to cause some weird problems.
You could also just take it all apart and clean up all of the connectors inside with an exacto knife blade and outside with a small stainless steel wire brush.
I also have fixed a lot of weird problems like those with "star fangled washers".
Take off any grounds from where they attach to the body tub, like the one next to the fuse block, grind down to bare metal, reattach the ground with the washer on the metal sharp side down, then screw down the cleaned ground terminal and once it's tight paint or cover with dialectic grease.
Do this anywhere you have a ground. There is one on the frame, one on the firewall, etc.
This may not solve all your problems if any at all but it can give you an idea.
If you have a short circuit or a back circuit somewhere, you can try to pull the fuses on at a time until it goes away but that will only help if you the short is on two wires from a different fuse.
Thanks I will try these out...... ya the light staying on part is weird because I unplugged the tail light harness and replugged it in thats when the light started staying on 5min before that it wasnt causing any issues?
So I fixed the grounds made all new ones ie battery to firewall batt to frame batt to ignitor sanded to bare shiny metal where ever I made a ground contact.
Still haven the same issues going on
dub,
take one circuit at a time and follow it from start to finish...get a wiring diagram and be patient..just about the time you think you have it figured out...you don't and something else will come up...one issue at a time...one circuit at a time...it is easy to get side tracked...check my other posts for some of the issues i have dealt with in the last several months...there is some real good info in there from idave and pinhead
good luck
osagecruiser
I just pulled the harness out of the fj I am going to check wire by wire for shorts or for crossed wires..... not my idea of a fun thing to do onSaturday my day off.
So The brake light issue is resolved apparently I am not that bright when it comes to setting up the brake light switch! So I grounded the tail lights now both brake lights work re-adjusted the brake light switch lights no longer stay on. I will work on the signal light issue tommorrow.
Question I was checking the wiring on the cluster the 2 main feeds possitive and negative there is a white/blue wire and a solid white wire one going to the possitive and one to the negative. When I was tracing out the wires today the white/blue wire goes to the fuse panel so it gets power and the solid white runs to the fusable link wire so that also gets power. the white getting constant power and when you turn the 40 on the other white/blue wire gets power..... I am thinking there is a problem with this picture shouldn't one of them be a ground? I know that there is a ground wire comming into the round plug on the cluster (ie the black plug that has like 10 or more wires in it)
No, these wires are both parts of the positive feed. With a few minor exceptions, there is no negative wire. Most of the grounds are to the chassis or engine. The + and - signs on the amp meter only indicate the direction of current flow into and out of the battery. The few ground wires that exist are all white with a black stripe. Everything else is a + supply wire.
