- Joined
- Dec 24, 2003
- Threads
- 136
- Messages
- 3,559
Hi folks a few questions if you would please pardon...
When replacing the starter contacts and starter contacts' plunger piece ...
1. Are you supposed to press fit the copper bolt and copper contact first trying to square the two together or do those get more properly pulled together by tightening the nut when that whole assembly is assembled together and squared by sight within the starter housing itself?
2. I've read and read the FSM and simply cannot comprehend what it is trying to say with the "up / down" and "long / short" description on the orientation of the square plastic piece that penentrates the housing. That piece in the kit that I got from good-ole-dan seems to be almost square with the hole almost center - now that's after three rum and cokes but the FSM makes that piece look rectangular with the hole off center?
3. Are you really supposed to squeze the contacts down with the wood in a vice? Cantcha just push them down with the wood by hand and have everything more or less square to the plunger? Any tricks to doing this or is the implicit way to do this to use the wood with vice method as the FSM describes?
4. What, if anything at all, do you all grease upon reassembly??? The plunger, the spring, the starter gear, the flywheel gear ... does anything at all get the grease and if so what grease is good?
Thanks folks, I appreciate it.
