some lift advice please
Richmond, va
I just purchased an OME 2.5 heavy/heavy lift and had some questions.. I searched but couldn't find the specific info I was looking for..
here is my question, I don't have bumpers or a winch YET, but wanted to install this lift now. So I was wondering if I should put a 1' spacer up front to level it out or will I need more in the front than that to make it look okay? I wanted to get it close without having to remove the springs once I install them. The reason I went with the Heavy rear is I carry a motorcycle on the back a fair amount and I wanted it pretty level when I did this.
thanks
Why does a "new" lift always need a spacer to make it level...?
Shouldn't the rig be level when you install a "new" lift on it...?
I have read that the rear heavy's cause some stinkbug action so just wanted to try and find out before I got started
thanks Hayes, I already have 1 inch spaces, so I will just take out the rear ones, I am not sure what that will take and didn't want to destroy the front spacers getting them out if the needed to be left in to level it..
If you throw a spacer up front to make it level, might the side effect be a sagging backend once you load your motorcycle? I'm running Heavies front and back with no spacers and no winch yet and yes, I am stinkbug, but once I load up the rig with stuff, it levels out. I'm okay with the unloaded stinkbug if the truck rides level loaded.
dogcatch'n--I'm guessing the back of the trucks sit higher so they take weight better, especially with Heavy springs that are meant for more weight anyway. Kinda like most pickups--they tend to sit higher in the back to ride better loaded.
The truck is not supposed to be level. You need more lift in the rear so that you do not have a saggy ass syndrome when the truck is loaded up. This results in headlights pointing to far up and poor handling.
For some reason most people do not like the slightly raked look.
Listen to the Man! You'll be looking all low-rider and stuff once you hang your motorcycle off the rear with spacers in the front. :grinpimp:
Yes.
Saggy ass is not cool.
I've never had an issue with the stinkbug.
Been running my heavy setup without any front-end compensation since day one.
He asked how to level, so I answered.
Long Live the Stinkbug.
But really, how bad is this "stink bug" look?? Anyone have pics of a heavy/heavy stinkbug?? I'm considering J's front and rear for mine, guess it'll be the stinkbug from hell.... hmm wonder if "STNKBUG" is taken as a vanity plate in NC??
Here you go. Just shot this on Friday. Heavies/Heavies, no spacers.
Tym - This is my truck with the 2.5" heavy/ heavy, ARB front bumper and winch installed. The picture is a bit deceiving because the driveway is a little sloped. I can tell you that the stink bug/rake is very obvious without any load in the back. I believe there will still be a slight rake with over 400lbs loaded on the rear of your truck (the way my truck is set up). I had (2) friends stand on the bumper and it only dropped the rear end an inch or so. Without a bumper and winch, you'll probably end up with reverse stinkbug with 400lbs.
tym--
my 80 had the j/j combo when you saw it last, little stinkbug but not to bad ( and no extra weight like bumpers/sliders/gear ) factory rake is 2'' lower in front for the tacos and tundras; i believe its the same for the LC but im not positive.
Everyone else has covered the stinkbug issue etc. etc. etc.
I'll just give you my two cents worth. I had the OME heavy/heavy lift (with the CC bushings) installed on my '97 LX450. Had the pros at Slee do it :D because at the same time I wanted to have the receiver installed for the Slee rear bumper I installed previously (requires the cross member to be cut).
Anyway, so I had the rear bumper on but did NOT have the ARB and winch up front installed yet. I found the front end to be REAL loose/twitchy in the driving department set up that way. Some of that I'm sure was due to the change from stock and getting used to it but most was probably from having weight in the rear and none in the front. Once I got the ARB and winch installed up front the handling came back to 'normal' and felt much more stable. I have a slight rake/stinkbug look when unloaded in the rear but I kind of like that look.
When loaded up for CM07 back in May with a 3500# popup camper in tow and weeks worth of "stuff" loaded in the back plus 3 soles on board the rig sat dead level :cool:
My one complaint is that unloaded the ride is pretty darn stiff in the back but that is to be expected. My commute is only 10 miles RT each day so I just deal with it rather than putting weight in the back to improve the ride but hurt my fuel economy.
The point of all this I guess is to say that IMO if you are not going to be adding the weight up front in the near future I would personally hold off on the lift install. The ride will be rough and squirrely without the weight the coils are designed to handle and putting the motorcycle on back will only exasberate the handling quirks further.
don't expect the OME caster bushings to correct for caster with your setup. You'll be way under with them.
Rick,
Is that the technical terminology for what I described as twitchy/squirrely handling? :D
Rick,
Pretty much. Another member just installed my caster plates on an unloaded truck with this spring setup. The alignment numbers after the lift was 3.3* left and 3.7* right. A little on the high side but still within the factory specs.
My plates effectively give an end result of 4.5* in caster change. The OME's give 2* effective change. No where enough unless you plan on adding lots of weight.
SteveVA--Here's a pic with the Heavy springs loaded for battle. No spacers up front. I think I'd be looking at the sky if I had spacers. Three loaded coolers, 10 gallons of water, tools, EZ-up, three bikes and all associated spare parts, camping gear, dry food, race food, stoves, etc., bike tools, bike work stand, chairs, Hi Lift, canopy, blah, blah, blah. It's good to start with the stinkbug.
I said I'd get one up so here it is.
Thanks for the picture, I got my lift installed sunday, now Im waiting on CC bushings and shocks, the stock shocks are a "bit" short in the rear :D.. I do like the ride though, much firmer than stock!!
