Solved my blower speed control problem
Richmond, VA
Well I solved my blower speed control problems.
I only had one speed, low and when I would press the other speeds it would only blow on low.
I went in behind the glove box and felt around with my hand while pressing the high button to locate where the relay clicking was coming from. It was coming from a little black box on top of the coolong coils up near the top of the dash towards the fire wall.
What a PITA to get at that thing. I hade to loosen the whole ac coil unit by remove all of the screws to just move it a little bit to get at the relay/resistor. The coils are still attached to the ac piping so I did not want to move them to much.
After about an hour I gotthe little black box out that said Denso relay it was about the size of a pack of cigs.
The plug was melted together at one small spot but I got it apart. I took the relay apart and everthing looked ggod inside except where one of the plug terminals looked burnt with a bit of melted plastoc around it. So I scraped and cleaned the ternimal and plugged it back in and WOW now I have all of my fan speeds back! I just jammed the relay back into the dash and closed it up.:bounce::bounce:We will see how long it lasts but now I can get at it easier if I need to.
This relay is also a resistor as well because it controls all of the other fan speed besides Low. That is what I found.
When I get a chance tomorrow I will pull it apart again and take pictures of the relay unit.
