So I’ve been chasing down these weak brakes for a while. Better now after bypassing ABS and it’s 3rd 2 man bleed. But still feels like a lot of travel before engagement and underpowered. I keep an extra following distance because I am positive an emergency stop wouldn’t happen.
I was doing the brake booster test where you pump the brakes up and then start the car and see if the pedal goes down. When pumping up this “clunk” or “skip” happens about halfway through travel before hitting the bottom. When starting the pedal drops to the floor as I guess it should. But this “bump” in the pump has me wondering if something else is wrong. There are no leaks - did a lot of checking on that front. Any thoughts?
I took a video of it - but not sure how to upload here. But here is YouTube Link
