Solo Motorsports LCA
Hiluxforever
Northern Front Range, CO
I am starting to plan for doing a suspensions refresh and need to replace my LCAs. These caught my eye since they push the ball joint forward an inch.
Solo motorsports LCA J120/J150
I think my biggest concern with these is that anything gained by moving the ball joint forward would be lost to scrub radius by going from a +20 to a -5 wheel
This is also an option. I may try it, but will be out of budget for mods 2026. Maybe in 2027 :).
JD fab has one as well. JD fab LCA Mount
If someone could come weld them on for me, that would be one thing, but I want to be the one that bolts everything up. Hence why I thought those LCAs might be novel.
I don't know how much you gain with the Superpro LCAs that have more adjustment.
I dont need long travel. I dont need two dampers. More rugged and better ground clearance would all be nice.
They do have a UCA designed for it, as well.
It will help with larger tires not rubbing on the back of the wheel well. Not sure how it may impact alignments.
Yea, I would have to run so much spacers or negative offset that I dont think I would gain more than 1/4" of real clearance since it will increase the scrub radius.
  • Like
Reactions: r2m
Tru put a new pair of oem arms on.
