Solder issue (in progress Temp Gauge Mod)
Los Angeles
I'm doing the temp gauge mod and I came up against something here. I used copper mesh to get the solder off the old joints and it worked perfect except on one. The copper on the board came off on that one. Not being a skilled solderer I didnt realize how nasty the new joint was going to look. It is making full contact with the diode wire, but as you see its not a full 360 degree connection, more like 90-180 degree connection. Everything looks smooth and shiny, but it still looks nasty. Take a look below...you'll see which one I'm talking about.
So my question to you guys is, "Does this joint look acceptable (read functional and safe) and if it doesnt what can I do to fix it since the copper on the board is missing?"
Howdy! Printed boards are a pain. I think your probably good to go, but you could add just a drop of solder right on the tip of the exposed wire, back to the line of solder you already did. John
