- Thread starter
- #21
I've a question - about to do this for my HAM antenna cable - how did you "Layer" the parts?
I seem to get some moisture down the back of that L part occasionally - the air vent below is well sealed - but I'm curious of how it all got sandwiched in - is the gasket against the metal or the plastic L surface?
The included gasket is sandwiched between Scanstrut base and the external plastic surface of the louver. There IS a slight gap between the louver plastic and the sheet metal of the body. I fabricated a gasket (out of a stiff rubber body filler squeegee) that filled that 1/8" gap. I'm sure many rubber sheet products could be used, but that was what I had available.
So the order of the sandwich is; Scanstrut cover - Scanstrut base - Scanstrut gasket - plastic louver - 1/8" fabricated gasket - body sheet metal. The four sheet metal screws hold it all together. No leaks.
HTH.
