Solar Questions
Dissent
Questioning my life choices...
GOLD Star
Sweetwater, TN (SW of Knoxville)
I've read the Solar Controller should be as near the battery as possible. I have two options for my Morningstar PWM 30 series controller; at the battery under the hood in a Pelican waterproof box or in the rear quarter panel 15 feet away connected to the battery up front with 2/0 cables with all my fuses and relays. I only have one 31 series Sears Diehard Platinum battery and will not have a 2nd.
The heat up front seems like it would slow charging and not be efficient as the ambient air would tell the controller to slow as it became hotter. It's going to be 120 degrees here on Saturday.
The 15 foot istance, based on smaller 10ga wire would have too much voltage loss, but wouldn't the 2/0 cable be about the same loss as if the controller was at the battery given the huge cable?
I need your experienced input guys. Thanks for your help.
First off, heat if anything SPEEDS charging, but the heat thing would worry me too.
With those huge cables, I'll bet you'd do fine with the charge controller in the back. Does that model of CC have a temp probe? You do want the charge to be temperature compensated, mostly to prevent overcharging, though with most Morningstar models topping out at 14.4 volts, that will likely be OK too. Post pics of your install, and how you got giant cables into the back.
3m tape on top of battery, no box, no problems. It is potted. The gasket on the box keeps most of the crap out. Ive had my morningstar there for years. My temporary setup has become one of those semi permanent jobs. I even made it into a battery tender (panel currently removed) by hooking up a 12v 5a power supply i had laying around and running the plug to the bumper. The controller doesnt care where the power is coming from.
Of course, if you want aux power in the back, wire for that. Put the controller anywhere.
How do you plan to run the wires for the panel? Mine is roof mounted with the wires running down the snorkel and under the hood hence the location of the controller. A mobile setup may change that a bit.
It does have a temp probe.
I ran the cables down the fender, through the driver's grommet, across the dash above the carpet (secured with Adel clamps), down the passenger wire channel to the rear quarter panel. the ground is also 2/0 and goes to a 5/16" bolt on the body in the lower well in that corner then a second cable from that bolt to another bolt on the frame. both bolts have paint removed with star washers and lithium grease. I'll post up a pic or two.
If the 2/0 cable negates the loss, The panel wiring will come through the rear passenger roof mount holes using waterproof glands or a Blue Sea deck penetration puck for multiple cables (lights, HAM antenna, etc.). I may run it down the A pillar to the battery temporarily or permanently. I'm buying one of NLXTACY'S Flaming River brackets and considered hiding the controller there initially but the heat was a concern. May play with it though.
I'm not sure about the panel yet. I want this primarily to have around town to keep up sitting in traffic with the AC blower and aux coolong fan and trail runs/camping but camping will be covered using my roof rack tent platform so I either need another panel for camping or fashion up a removable portable solution. I envisioned a slide out setup but my Prinsu rack won't accommodate that. I don't have accommodate fridge yet so I may just remove it when I need to and run accommodates extension cable.
Pronto :clap:
Yes you do! There are atleast 25 of us waiting for that to happen!
Okay maybe not 25 but close 3!
Here's some pics of the 1/0 AWG cable I ran. I thought it was 2/0 but I just found the receipt. At ~20 feet, it should carry 140-160 Amps.
$ 180 ea - 21 feet 6 inches - (through frame) 1/0 power (red) cable terminated in 5/16" & 3/8" HD Rings,Mega Wall Adhesive Lined Heat Shrink Tubing with Semi-Rigid Wrappable Split Braided Tubing
$ 35 ea - 33 inches - 1/0 ground (black) cable terminated in 3/8" & 3/8" HD Rings, Mega Wall Adhesive Lined Heat Shrink Tubing with Semi-Rigid Wrappable Split Braided Tubing
I wanted to have more than enough capacity in case I ever bought a receiver mounted winch. I was already running a 4 AWG cable for the amplifier so it didn't take much more ($100) to run a larger cable. I had it premade to length with all the ends crimped with a hydraulic crimper. It was going to go in the frame but I couldn't make it work so it's a bit long, the loop fixed that and gives me adjustability too. One day I may ditch the plywood and go with an ABS sheet.
It's clad with abrasion resistant expandable sleeving. I don't have a pic of the ground lug from body bolt to frame but it's not too hard to visualize. I also found I don't have pics of under the dash but I have more rubber lined Adel clamps above the gas pedal and where it exits the heater box to the passenger side. Nothing moves.
Battery, across charcoal canister bracket and ABS bracket, through driver's grommet on firewall. Hasn't moved at all in 3 years.
Overhead view of Battery to Firewall. That's an OEM battery ground cable (4 or 6 AWG?).
y3mFub5xzof5iD9Qqz3JESkig9ZDXuvqmR55_OUeLCAIIn0H4A7p8gkF1QYPW_QNJigawQeeBh4EYVVM4LNnLzy5mMCI2S1gxcQTWkZlV5wl8oo2WzjukYIX0TeQOAdkq9xeu-KH-tdaBCTca1EHkVJWA
Coming out of heater box, across driver's feet area, going down into passenger wire channel. Perfect fit.
y3mqJAuHPpxhiyshgDR0BEhTiKbeoMqHc2qasBQ6XqhoVUNz56tgyHkyXVsRylfWfSA6NdmIpa-HnjCztwz1yHZarI_xP0igCNVvscOpHMNPPI6nv2Kb9vp4DJRpPN2kR0y_Jl4Xt6O3BtVsdTXnebGrA
Tight fit behind the 2nd row seat belt mechanism with other wiring. Lots of abrasion protection (loom, grommets, vacuum hose on body, etc.)
y3m74RJFkHXkV57uOdpmmNYuMQqvo2Fa_5bQcA2_3q1eRldcUXFPbPW8OsIkSoaJDU3CNg5z9SKnop1kyDS3qWa_PDF2LECNPSXZoUzIEP7SJQUb1rna31MdTHVyrqK57g1hy7eIk4lxyyntSpSnLSocQ
After the seatbelt, into the rear passenger wall area.
y3mWbXLn1xGqCMClE5lZHuSGqNzyK5yMC0AdvHWmDRHwpT-uJBXOnVFGBmic1oB-FlJD7qroBvYvJZzOsksUf0BHhvXVSSrEL8l2a6kzxmPw2Sm5lK7xEdcwNLemB8RHf-_QyxA3vAuEfNtcKmH-wfIhA
Cables run to the rear.
y3m6FxtXXa7uSLR_nI1qCA_wpI_o0H90SB6hHYkIj9jGmWZYn3WONhhyBo43UdOrMrbtPYMeD3J8iuqc_UeqHcmtbYKFKa79wkJj2xl0v_fU37gHS311XE6ELmw6RKi6reVFE6wWmUWH8q3m_xCh_jMRA
Ground lug in rear passenger well. This is the only way I could orient a drill from underneath. Much better than passing the cable through the body too, no abrasion.
y3mbJ1ze9fqcyzhiAhOuUTguDXiaOcpfaHhTDpxWNYcJmqk_4UL7IDK4-dEcwsZlufQraS8EEGdC2n5vOlYfC56Hrzhxn-CmdzMuhu502njvIVOkNDHOWA2b2OUK-ik9wFAEvzevRv9qhyWqHh4brT01A
End result. Feeds amp, lights (future), fridge (future), rear outlets, etc. Not much room for my MorningStar solar controller but I thought of that very late in the game. Luckily @NLXTACY came up with an idea....not a product per se...but an idea that will fit the bill...one day... :rolleyes:
y3m2K-3dHSDWUVnC_ErPNq_eQGAEzdxbB18LH8iANqsv2uqqtbrcl8p_cOZWjjrKvR3ntg0rxBDNoAUAg1RnCOt2P6TqYEc9HzSuSbehhhUP-zKB9VJqItf8vr4Yv9bRuiE5Al_51olB97fwmbsBXpqhg
Nice. what you got going on there and what you planning on powering/connecting
Relay Bank
Bank of 7x 20/30A and 1x 40A relays for future lights and other stuff. I have a bank of OEM switches going up front with 20AWG turn on wires running to these relays.
Above the relay bank on the left is a screw terminal block from those OEM switches.
Above the relay bank on the right is a screw terminal block which are outputs to the future lights and other things I might implement.
Blue Sea Fuse Block
In the middle is a 12 circuit fuse block with ground for running all the lights, outlets, fridge, solar controller input, etc.
Anderson Plug
The SS75 Anderson plug below the relay bank is where I plugged in my Puma compressor originally but then relocated it to the drivers' side. That Anderson connector now connects to an 8' extension that runs to the drivers's side.
3/8" Positive and Ground Lugs
Below the Anderson connector is the 3/8" Blue Sea lugs for the incoming 12v positive and negative leads. Cables connect from there to the amplifier, fuse block, high current fuse block, solar controller, etc.
85A Solenoid
To the lower right of the Blue Sea fuse block is an 85Amp Cole Hersee 24106 Continuous Duty Solenoid that controls the Puma compressor. I have an OEM dash switch to turn the compressor on. The 6AWG wire comes from the FMX fuse block above the solenoid to the Anderson plug.
Low Profile FMX Fuse Block
This fuse block has 2x 60A FMX "JCASE®" fuses that feeds the 85A Solenoid/Puma Compressor and another 6AWG wire that runs back up to the passenger seat with a Blue Sea 6 circuit fuse block to feed the center console and inverter.
Ancient Alpine MRV-F450 Amp
My ancient Alpine amp is crammed in on the right side. This thing's been in 4 cars now and is about 13 years old but still going strong. The large black plastic corrugated wire protection tubing contains the RCA signal wires running from the stereo in the dashboard.
Mounting
Everything is mounted to a few bent 1/8" aluminum straps that hold the amp and 3/4" plywood in the fender well. There's a pencil tracing that includes most of the relays and the fuse block that indicates what's accessible from the removable access plate in the plastic wall panel. I do have one fitment issue and that is the wall panel won't fully snap in place under the 2nd row seat belt. I need to space that brown plastic panel clip out about 1/8" somehow.
Other Stuff
I've attached 3x 40A relays to the battery tray up front along with a small 6x circuit exposed fuse block. The 40A relays were intended for a large LED light bar or incandescent lamps and an aux cooling fan I picked up. Probably going with a low draw 100 series A/C fan in place of the other fan.
Plans
When I win the lottery, I plan on putting up front/side/rear floodlights, my mirror mounted flood lights and puddle lights and some sort of large front spot light. I also plan to install LED undercarriage work lights, rock lights, a fridge, HAM radio and some other goodies.
