Hey guys here's something I read and was curious about. First off, this came from a range rover site so they are obvously going to talk highly of their rigs - but I thought this was interesting:
The Range Rover Secret: Suspension Design
Range Rovers have always been distinguished by innovation in suspension design. The Classic Range Rover was able to use exceptionally soft springs, while retaining a 1600 lb payload capacity, by virtue of the Boge self-levelling strut fitted to the central A-frame link on the rear axle. This is, in effect, a variable rate self-adjusting air spring which provides a restoring force on the center of the axle to compensate for load, allowing very low spring rates to be used at the road wheels. This results in maximum possible traction on uneven terrain.
Why does a soft suspension give better traction? This is a secret that other 4x4 manufacturers and aftermarket suspension builders have apparently never learned. When a wheel droops even an inch or two on uneven terrain, that wheel is "unloaded" -- ie its ground contact force is reduced -- in direct proportion to the stiffness of the spring and anti-roll bar (if fitted). Any loss in ground contact force reduces available traction at the wheel in question. With an open differential on the axle, traction is lost at both wheels simultaneously.
Conventional and "lifted" 4x4s overwhelmingly use leaf springs or stiff coils with anti-sway bars tuned for flat high speed cornering on pavement or supposed "heavy duty" use off-road. Aftermarket "upgrades" invariably include even stiffer springs, shocks, bushings and/or anti-sway bars. The net effect is a very stiff suspension that not only provides less maximum wheel travel (resulting in wheels lifting off the ground in very uneven terrain) but much reduced traction even in mild off-road situations requiring only modest vertical wheel movements.
This is why the conventional dogma dictates that serious off-road vehicles must use "lockers" on the differentials to maintain traction. Lockers force both wheels to rotate at equal speed, transferring all the torque to whichever side has the grip. They therefore greatly increase stress on the drivetrain components, and have adverse side effects on steering control.
I guess my question is - do you guys think this is BS, and they are trying to make up science to support not having lockers from the factory? It is true that most offroad suspension mods stiffen the springs instead of softening them (OME medium, stiff etc). I have read on MUD many times that SFA LR's have great axle articulation. - and that the real plus of having a SFA is to keep both front tires on the ground as much as possible - so do they have a point that springs should be softer as opposed to stiffer?
Of note as well is that the RR classic has more payload than an 80 series (according to the above text anyway).
Also - my goal here is a suspension design discussion not a LR vs LC discussion.
Also keep in mind that I'm not really talking about rock-crawling here - more expedition-style off-roading as both of these vehicles were designed for.
Thoughts?
Thoughts?
