For Sale SoCal - OC 2011 GX460 full overland build 27k
San Diego
Year
2011
  1. GX460
Mileage
183000
Color
Black
For sale: 2011 GX460 with 183k miles.
It is modified with many useful systems including a long range fuel tank, giving it a 600 mile range on 1 fill-up.
All maintenance up to date. I'm selling to get into a truck camper, this rig is much more capable than what I use it for.
Price: 27k without fridge and arb compressor, 28k as listed.
INFO:
Mechanicals within the last 2 years:
Radiator
Water Pump
Spark Plugs
Spark Plug Tube Seals
PCV valve
EGR valve
Ignition coils+wires
Unifilter replacement for secondary air injection system
Valve cover gasket (NO valley coolant leak)
Suspension:
Kings 2.5” diameter shocks with adjustable front and rear remote reservoirs - Installed 7/2024, 8k miles on
Built Right UCA
Polyurethane LCA bushings
OEM tie rods left+right
Timbren Bumpstops front and rear
Dobinson 800lb constant weight rear springs - no sag fully loaded with 2x 5g jerry cans, 5lb propane tank, and 24g aux fuel topped up
Rear track bar re-leveling drop bracket
285/75r17 Bridgestone KO2 (34”) Tires - installed 6/2023 with 11k miles on them
Armor:
Expedition One rear dual swing out bumper with custom hydraulically assisted swingarms
Long Range America 24g Auxiliary fuel tank
Auxiliary fuel tank skid plate welded on
LFD front skid plate
White Knuckle Off-Road sliders
Electrical:
100Ah Ampere Time LiPo Battery
Victron DCDC charger
Victron Solar Charger
200w Rigid Solar panel
1200W Pure Sine Wave Inverter
ARB Dual Air Compressor
BluSea DC fuseboxes
BluSea magnetic relay in engine(un-used, for optional backup battery expansion)
X2 930CCA AGM Battery 12/2024 - $400+ battery (Voltage boost diode for AGM installed)
Chinese relay switchbox for lightbar + camplights
Misc fuses and monitoring electronics - Everything is fused, everything has cutoff switch for maintenance
Misc:
Rhinorack Batwing 270 awning
Gamiviti expo roof rack with custom rear perpendicular bar reinforcements
MIA Adventurer tent with blackout 600D fabric
Dometic 75qt fridge with slide
Retrofitted MTS and craw control switches(this is not available from factory in this year and trim)
3rd row delete with custom floor plate and drawer, utilizing as much space as possible
40% 2nd row delete with airbag bypass (No airbag lights for missing seat)
All original OEM seats included with sale
Nice truck. Looks well thought out... now, if it weren't so expensive to ship out east....
This thing still available... or is she gone?
This thing still around? I just got back in country and was working my way though the forum update trying to see what was out here.. Found you in the archives...
@Gx460sd your rig still available for sale?
