SOA with fj60 axles - RuffStuff Kit - 0 degree vs 10 degree caster plate
Rural NE California
I will be putting fj60 axles with a soa lift in my 69 fj40. I would like to purchase the ruffstuff kit as it is on sale, but need to choose 0 degree or 10 degree caster plate. I plan on doing cut-n-turn to correct caster after pointing pinion up more. I assume I would need the 0 degree caster, but here to confirm. Can anyone give me some guidance?
What driveshaft are you going to be using?
If you are using the factory 40 shaft you want the angles to be the same at each end, use the 0* perch, If you are using a double cardan shaft point the pinion straight at the output pinion on the t-case. You want the axle pinion and driveshaft angle to be set at 0*, the 10* perch help achieve that with less grinding.
I did this exact set up my build
