SOA spring clips
Olympic peninsula WA
I am in the middle of doing a SOA and in my past life i cut the spring clips off (the ones that are rivited to the leaves and wrap up around to hold the seperate leaves together) of the stock leafs when i pulled them apart for cleaning and anti-sease. Do i need to make new clips or will it be ok without them on there?
Thanks
dustin said:
I would run them since your springs can start to spin around a bit.
I too keep mine open, and drilled holes in them, then ran a bolt through, kinda like how OME's are.
I would replace them. OME's are clamped in the front. They do have the bolts in the rear. I have watched two people bend their front main leafs when they were at full droop with open clamps, and then they needed two go in reverse.I did the bolt thing on the rear, but I don't think a bent main leaf in the front is worth the extra inch or two of droop.
aw
