So what should I do next?
West of the Pecos
Bought my '92 in May 2006. Here's what I've done so far:
- New tires - summer 2006
- New AC condenser and converted to R134 (or whatever that new "freon" is called) - summer 2006
- New OEM U-joints - summer 2006
- New 100 series brake pads, fluid, and brake lines - summer 2006
- New OEM belts - summer 2006
- New OEM air filter - summer 2006
- Roof rack removed - summer 2006
- Repacked birfs, replaced seals and bearings etc - fall 2006
- Replaced fluids (trans, front/rear diffs) with Mobile 1 sythetics - fall 2006
- Turkey baster thing to replace much of the power steering fluid with synthetic - fall 2006
- Tune up - new plugs/cap/rotor (wires were replaced by P.O.) - summer 2007
- New OEM fuel filter - summer 2007
- Been changing oil with Rotella T 5w-40 or 15w-40 synthetic and OEM or NAPA Gold filters
- New OEM starter contacts - fall 2007
- New OEM radiator - Jan 2008
- New OEM thermostat - Jan 2008
- OME 861/862 springs and OEM shocks - Jan 2008
Hmm... That's about all I can think of off the top of my head.
What else should I plan or be prepared to fix over the next year or 10-15k miles?
edited to add: Also, right before I bought her, the P.O. bought a new OEM battery and had the power steering pump replaced. Also looks like the fan & fan clutch are fairly new.
I know that we are just 28 days into January, but how do you like the OME 861/862 with OEM shocks? I am planning to go the same route pretty soon and wanted some feedback.
As far as your list, looks pretty good. Did you change out all of the obvious hoses when doing the radiator & thermostat?
Riley
A full PS flush. I tried that turkey basting thing and it would take like forever top get it clean. I coughed up $70 for the dealer to do it. One of the few thing I let them do:)
You now need some more mods!
Bumpers, sliders, George's LED's,winch well the list can just go on and on:popcorn:
Maybe rear axle service?
Lots of good maintenance on that list. My goal is something similar. I'd like to have the mechanicals all buttoned up before I start dropping the real money on mods :censor:
Riley
Yes on new hoses. Haven't changed all the vaccum hoses (yet). I used up ALL the vaccum hoses in town when I did that to my '90 4Runner. :eek:
The OME springs and OEM shocks are GREAT!!! VERY noticeably better ride. I knew it was "wallowy" before, but I had kinda gotten used to it. Before, my measurements from center hub to flares was around 19.75", give or take 1/2" or so depending on which one you were measuring. Now I'm dead on 20.75" in the front and 21" on the back. Doesn't look "lifted", but it makes the 265 tires look like they shrunk!
...You now need some more mods!
LED's? :confused:
Next thing I'm doing is getting rid of the chromed alloy OEMish 16x8 wheels and getting some black 16x7's, since I'm running 265/75 tires and will probably switch to 255/85 Cooper S/T's when these wear out.
After that it'll be time to pull the ribs off the roof, pull off the flares, plug all the holes and do a home-rolled paint job (clearcoat looks pretty bad in places). Then ARB on the front and eventually maybe some kind of rear bumper that will haul the spare and a jerry can or two. I have the spare double bungee corded on the floor in the back right now - I HATE the way it looks hanging underneath. I even ditched the receiver hitch because of how low it seemed the hang under the truck... 3FE's got no business pulling trailers anyway.
I've already spent close to what I paid for the thing trying to just keep it running. Hopefully, I will be able to throw some money at the FUN stuff for a while!
