So what is this for?
oregon
This small hose in the fire wall on the passenger side. I just noticed it dripping water today. I searched for it on here but cant seem to find out anything about it.
It just behind this heat shield.
So...??????
That's the drain hose and grommet for the AC system. You can see a picture of in the the FSM under cooling unit disassembly.
Pete
OK, So why would it be draining water? Its not pouring out, but it was putting out a steady drip that lasted about 5 minutes after shutting down the truck. I have not run the AC in probably over a month.
Were you running/using the defrost? That normally causes the AC to kick on to dry the air
Do you have the auto climate control? It wants to kick AC on all the time.
BTW, where in Oregon do you live?
The drain may be partially blocked and it is draining residual condensation.
Pipe cleaner?
It is probably 3 inches or so.
No. I had not run the defrost or the heater at all today.
The hose drains any moisture that gets into the evap box. Has it rained, washed the rig, the fresh air intake is the grills behind the hood, it's possible for water to leak from there into the box. If you not getting water on the cabin carpet I wouldn't worry about it, it's doing it's job.
