Note to self... check function before closing doors...
I have a new actuator waiting to go in a door with an intermittent issue. I'm sure this thread will be burned into my head...
The problem will no longer be intermittent once it heats up.![]()
Did you pull the door handle screw and the power window switch to see how much room you have to access the inside? I did it once on a Lexus but I had the panel off.
Well I now have the tool to pop the child safety if anyone needs it in the future..
lol
So here I am, six years later with the exact same issue. Of course I thoroughly read the DIY Door Actuator thread to make sure I had every detail accounted for before diving into this. Spent 3-4 hours changing out all of the actuators, go to shut the first rear door and *BOOM* — immediately realize I forgot to attached the door handle rod (yellow clip). Stupid. But hey, it's just one door, right?
So I'm extra careful and thorough as I do the second rear door (passenger), double check everything, close it and *BOOM* it won't open and the lock won't engage. So here I am with one door with exterior handle disconnected (child lock on I presume?) and the other with the tiny wire that connects the lock actuator disconnected and permanently locked. FML.
Question 1: Does anyone have any details or info on the "coat hanger" trick to get the child lock? Location suggestions on where I should be prodding
Question 2: Anyone have success removing a door panel with the door closed? Any tips would be helpful since I've tried doing the simple approach of leveraging a crow bar on the door frame and trying to lift the top edge off.
After mulling over this with constant web/forum searches for the past 2-3 days, I'm at the point where I'm prepared to saw off the door panels to get at the innards and then fork over the $350/door panel to replace. A cost-saving DIY turned into a $700 mistake
Any help is much appreciated!
I know this is years ago, you mentioned you have the tool but I couldn't see what it was.Well I now have the tool to pop the child safety if anyone needs it in the future..
lol
---------------Hey there. It's been a while since I was in there, but I wasn't smart enough to leave the inner door panels off (like you). What I ended up doing was forcibly tearing the door panel from inside the truck, and then I was able to reach in and grab the rod to unlatch the door.
In your case, the outside door handle should actuate the door (if the rod is connected) and if no, you should be able to do this by hand? If it's a matter of the actuator being broken/jammed (which you just replaced the motor in) then shouldn't you be able to manually pull the cables to unlock?
I know how frustrating this is, so I wish I could help more. Perhaps some pictures of what you've tried thus far would help since many of us haven't been inside those doors since we last tackled this almost a year ago. Here to help!
