Build Snoopy Build
OME mediums in! Next I'll be going with Nitto Terra Grapplers 297/75
Snoopy is looken mighty sharp and ready for action.
Have you heard about those 3° caster correction bearings Slee has? This would be a good time to correct caster & camber if you have not already address it. I do not have them, but I'm looking that direction when it comes time for me to do my front end.
Well this is a giant pain in the balls. Finally got it all off. Gotta rough sand, tape and rattle can. Then put my awesome @reevesci rack back on. On the bright side after letting the screws soak in free all over night, all the nutserts stayed put. This will be a simple "screw covered in seam sealer fix before the paint.
[QUOTE="Explorer4Hire, post: 10017003, member: 111468"
Well this is a giant pain in the balls. Finally got it all off.[/QUOTE]
Looks like you got through it just fine. Couple trick I learned in the trade. A heat gun really helps with removing adhesive or decals. For the foam stuff you where removing an adhesive wheel in a cordless drill makes very quick work of that job. Ten minutes tops and you would have had that off. Makes a bit of a mess, I will typically take a blown gun and then some mineral spirits for the final clean up.
Sent from my iPhone
Yea. I went the hard way. Some of those spots are bare metal. But it's treated and primed now. Paint in the morning.
So next on my list is:
Sliders
Rear swingout on factory bumper
Knuckle service and new rotors/extended brake lines
Final coat is drying. There are a few gouges and a little adhesive I missed. But it's definitely adequate for temporary work until I figure out what I'll do paint/liner wise. The better prepped areas look good. If my timetable for a family trip wasn't so tight I would have prepped a bit more. It will look well enough once dry.
