I need to have my engine smoke tested to eliminate a vacuum leak being the cause of a lean-miss I'm trying to solve. Does anyone know a shop in town they can recommend? Any place I should steer clear of?
He swapped the motor to a diesel, so, yes, he resolved it.
My theory is that the 3fe runs lean on the center two cylinders due to the design of the intake. Add an unregulated intake leak, too much timing and a heat soaked cylinder head that runs hot in the middle and you detonate the center 2 cylinders.
