smog help...
Maybe someone can help with the "problem" --- first some background --- I have a stock 79FJ40 with the original rebuilt carb and ALL of the smog stuff intact. The problem is the truck starts just fine but after it begins to warm up (about 5 minutes or so depending on outside temps) it will begin to run rough and require the manual choke to be pulled out about 1/4th in order to maintain an unassisted (no pedal) idle. Strange thing is as the truck gets driven around in that condition for about 10-15 minutes the engine RPMs will pick up substantially and I can release the manual choke -- she then goes back to idling perfectly. Now with the summer heat -- 95+ degrees out --- the time between when the choke has to be applied and when it gets 'hot' enough to release the choke is much less.
Any suggestions? And no, this is not a manifold leak -- I've checked that by all the recommended methods and no leak present. Also, ignition timing is dead-on.
Thanks in advance for some tips/advice.
Tom
It sounds like a vacuum leak that changes with engine temperature and if it isn't the usual spots that you can find by spraying carb cleaner or propane, it may be a sticking EGR valve. In 1/79 toyota went to an EGR that connects to the intake manifold, so that would cause more of a vacuum leak and idle problems than the earlier style that enter the carb above the throttle plate. You can see the operation of the EGR push rod that opens the valve. It sits between the vacuum modulator on top and the valve body below. Put a mark on it and pull a vacuum on the modulator and see if it moves freely or if it is stuck. They can be cleaned with carb dip (just the valve body and not the vacuum modulator) and lubed with graphite. It could also be a cracked intake, but I would think that it would get worse the hotter it gets.
