Smell:Has something died??
Hi
My Kids are accusing me of gassing out the cabin of our 80. It is a 95 4.2TD VX spec. The smell is in the ventilation system. The carpets are dry and I have run some water through the vents in front of the screen and this appears to drain OK behhind the wheel arches.
Any ideas or thoughts would be appreciated (mainly so I don't keep getting the blame.
Regards Peter
Does it smell sweet? Like hot coolant? If so, you may have a leaking heater core. Bad news. If not, the other bad news is you have some growing funk somewhere in the HVAC. Major dash removal project. Good luck.
Mine smells in the vents when you put on heater or air, you can buy some stuff in a can and spray it into all the vents and it gets rid of the musty smell. I just used a bit of glen 20 and it worked for about 6 months.
Thanks for the replys guys. It smells a lot like when the bottom of an old pond is disturbed! Rotting stagnant.
Thanks Peter
X2 on Crusier88, I bet you have mice. Do you have little poo dropings on or around your battery by chance? That's a good tell- tell sign that they are out to get you. ;p
