I was given a small Johnson Seahorse outboard that I believe to be about 2.5 HP. It has no spark. The plug looks fine and is gapped correctly, I cleaned the contacts on the coil, and still nothing. All connections are fine, and the points look and function fine. I'm hoping the problem isn't the stator because, in that case, I'll probably junk it. Is there anything else I may be missing? Can I test the resistance on the ignition coil somehow? It would be cool to get it running again. It's old.
