Small clarification with pin7 mod
Eicca
Professional Noob
Utah
I've done lots of reading on the pin7 mod but I'm kind of confused. I read all sorts of stuff about the t-case connector and the CDL switch itself and I'm not sure if I have to mess with those while doing the mod or if I can just pop out the wire as mentioned and be ok.
So basically what I'm asking is: I just pop out the wire and be done with it, right? No messing with anything else?
And yes I've got a CDL switch.
:beer: Thanks! :beer:
It's very simple. You will enjoy Low range more thoroughly. :hillbilly:
Tape off the exposed wire when you're done, too, so it doesn't ground out or anything...
In addition to this, my 93 doesn't have a CDL but does have the magic locking dial. Will the 7 pin mod let me use the CDL in high range as well as turn if off in low if needed, if I add a CDL switch. Or is the CDL not ment to be used in high range and speed?
You can use the CDL in high. Generally in loose/soft sand or snow. Get the CDL switch and with the 7 pin mod you can lock and unlock in either range at will. You will have to remember to lock the CDL first though in low range when you want to lock your axles.
So I have to have the CDL on to lock the axles? Can't I lock the axles in high range with out the CDL locked? Shouldn't I be able to lock any of the 3 in either high or low range if I get the switch and 7 pin? Except for the fact the rear has to be lock to lock the front, but you get what I'm saying. I'm thinking of for a muddy or snowy corn field, where low range is way to slow and I want power to all wheels equally at a higher speed.
The center diff in the transfercase needs to be locked in order to "arm" the front and rear difflocks. It doesn't matter what manner is used to lock the center, it only cares that it is locked.
I so enjoy crawling around in the woods in low range with one wheel drive. Hardly leaves a mark.
Holy freak. I'd use Low range when off-roading and I thought it was way low. Tested it out on the roads and now I realize it's looooooow. I like it :)
I find that there's a lot of confusion around the Pin 7 mod...
Some clarification-
1. A CDL switch allows manual locking/unlocking of the CDL. Nothing more.
2. Factory setup: The CDL will automatically lock in Low range.
3. Pin 7 is performed to allow UNlocking of the CDL in LOW range (with the CDL switch)
4. The Pin 7 mod is NOT required to lock the CDL in high range.
That's my understanding of it, and so far, it makes sense.
Like Dan said, the Diff Lock ECU only cares that the CDL is engaged in order to engage F/R diff locks. Whether the transfer case is in High or Low range doesn't matter.
:cheers:
If you really want to push it, an 80 WILL do 50 MPH in Low range and CDL locked. Not advisable, though. :steer:
Some clarification-
:cheers:
So with the CDL switch installed and pin 7 NOT done, if I shift into low, the center diff will lock automatically and can not be unlocked. With the 7 pin mod, I can unlock the center diff when in low after it automatically locks.
Not exactly.
The pin7 modification elimintates automatic locking of the center differential when the vehicle is shifted into low range. The diff must be manually locked by the switch.
Think of it like this:
When you have the switch AND you have done pin7 the transfer lever controls only high and low range and the switch controls only center dif lock and unlock.
You have two separate systems.
x2 what Dan said.
Like I said, there seems to be a lot of confusion around this mod...
