small bolt pattern 4x4 Labs highsteer
Trollhole said:
Here is an interesting question. COuld you drill and tap the smaller knuckle bolts for a larger stud?
Do the knuckles with the larger studs have any other differences than the ones with the smaller studs?
LC_Hamma said:
I ran a 12MM tap thru mine
Seems to me, he just stated that he ran the tap through the 11mm hole....
The later castings seem to be beefier around the knuckle bearing areas...but I have seen those fail also...
:beer:
Well fawk, we all do some foolish stuff don't we :flipoff2:. Not gonna complain - it's still going to be better than what I had. I bought the small pattern about a year ago planning to do a quick springover but other stuff came up and it got shelfed for awhile. If I'd known it would take me this long to get started I would have swapped - Luke had no problems selling me the small pattern high steer arms - for now I'm just hoping they clear my springs.
Gumby said:
The larger pattern knuckles should be common as dirt. They came on all the 60s and the minis from 78-85. You can use everything but the steering arm and the lower trunion. You will also need the larger cone washers.
Dropping the cash on a high steer would be foolish without picking up some bigger knuckles, IMHO.
Luke at 4x4 Labs is likely to tell you the same thing.
