I want to get lower gears with more options than my current set up with my 2f, h42 and Orion. After a lot of research and disapointment from marlin(no toy boxes available) I am considering getting a sm465/atlas 4 speed combo.
A little info on my rig-
Throttle body injected 2f, h42 , Orion, 4.88 diffs and 37inch tires, may go 39 eventually and fj80 rear axle..
I understand that first gear in the sm465 is not synced and can be a burden at times. With that being said, I think having the option of 3 separate low tc gears I could wheel primarily in 2nd and 3rd gear saving 1st gear for real technical obstacles.
The sm465/Atlas 5.4:1 will give me options of-
1st gear -63.9:1, 86.9:1, 173.8:1
2nd gear -34.9:1, 47.5:1, 95:1
The sm465/Atlas 10.3:1 will give me options of-
1st gear -86.9:1, 121.4:1, 329:1
2nd gear -47.5:1, 66.38:1, 179:1
I would prefer to stay with my h42 and strap on an atlas, but cant find a way to do it. The only reason I am switching to sm465 in so I have the Atlas option and to get a nice flat belly. The Atlas 4 speed also costs the about the same as an orion/toybox combo and it is about the same length.
Does anyone run this setup, and does anyone have any other reccomendations of a way to get an Atlas behind a 2f?
Thanks.
Thanks.
