SM465 AA adapter question
Afton VA
Over the past year or so I have been collecting parts for a SM465/3spd tc to replace my stock LC 4 speed/4spd tc. I have picked up the 3spd tc and bell housing and I’m looking for a SM465.
I just picked up a used AA adapter off of Ebay. I wasn’t planning on going this route because of the extra length but I got for $115 shipped:D The kicker is that its for a 10 spline SM465 to a LC 4spd tc:confused: My questions are:
1. If I flip my rear springs (4” HFS) will this buy me enough room to avoid drive shaft mods?
2. Can I swap the 16 spline input gear from the 4spd tc into the 3 spd tc?
Thanks!
The 4 gear will not work in the 3 speed.
Contact AA and ask if they will swap out the 4 speed shaft for the a 3 shaft. IIRC, that is what I did. I think a new shaft from AA is $125 IIRC? Call them ask.
jcj_78FJ40 said:
I saw this on the Tech pages:
http://www.toepper.net/Landcruiser pages/4_speed_trans_3sp_xfer.htm
Anybody know anything about this? I'm assuming the only reason someone would put a 3 spd gear set in a 4spd case is to do it with a 16 spline input gear so it will bolt up to a 4 4pd tranny.
The reason you use the 3 spd gear set in a 4 speed case is because the 3 speed set is lower geared, but the 4 speed case is supposedly stronger.
Is the shaft you have 10 spline or 16 spline?
Why not just use the 4 speed t-case?
The 4 Speed t-case is quieter. The transisition gear is available for about $85 from Cruiser Outfitters and other vendors.
Thanks!
i have a 10 spline sm465, if you can't use that adapter then let me know and i'll buy it from ya.. ;) i need one ..
Thanks ... and Cheers. .. :beer:
The AA adapter is for a 16 spline 4 spd TC. I would like to use the 3 spd tc that I have sitting in my garage for the lower gears. I will check out that transition gear, the one from Marks was about $125. As mentioned earlier, maybe AA will make me a deal on the 10 spline output.
I'm just trying to find all possible options.
Thanks!
I very well may sell it and go with the Classic Cruiser plate adapter. I want to get the rest of the components before I make that decision. If I do it will probably be in the late fall. I’m sure I will post it in Mud’s “for sale” thread.
