sm420?
I just found what I think is a 420. It has a reverse bump on the passinger side and the pto plate on the left side. Anyone have a picture of a 420 to compare? The problem is this has the big input shaft and I will have to change this out if this is a 420. Anyone have a small input shaft or know a good place to buy one? This is out of a 1969 1.5 ton truck.
Here ya go...
Thanks this is just what I am looking for. the trans looks just like the photos thank you for the fast replys. now if I can find a input shaft and a conversion plate for the 3-speed transfercase.
no input shaft needed, it uses the stock one..
fjdreamer said:
It his has the big input shaft and I will have to change this out if this is a 420. Anyone have a small input shaft or know a good place to buy one? This is out of a 1969 1.5 ton truck.
What does this mean?
If it really is a 1969 tranny I would guess (without seeing a pic) it is an SM465. Still a good transmission but if memory serves first gear is not as low as a 420. (6.55:1 vs. 7.05:1)
Common 465 trannies had a 35 spline output shaft with exceptions for the 4x4 version.
Common 420's had a 10 sline output with exceptions for some 2-ton applications. I'm sure there are other exceptions as well.
I've heard there are some 1968+ SM420's that were military spec trannies.
What I mean by the big input shaft is the chev big blocks in two ton trucks use either a small input or a larger shaft and a 14" clutch and they have a adapter for a larger bellhousing. This is a 420 with a large shaft and I have someone looking for the small shaft
There were AFAIK, no SM420 trannies produced after '67 except for the ones specially produced for the military Gamma Goats. These trannies are the same as the '67 model civilian trannies 'cept for the lack of a PTO cover, a funky remote shifter linkage top cover, and no reverse switch.
These Gamma Goat transmissions are commonly available through army surplus channels, I run one in my '40 and it works great.
http://www.avettruck.com/
I paid ~$400-450 shipped IIRC
Remember you will need to source a topcover off of a regular SM420. I posted an ad on pirate and had one in a week or two. Cost me an additional $75.
A toyota 3 spd shifter will drop right in, or you can modify a 4 spd shifter fairly easily if your top plate does not include a shifter.
