The PTO appears to be an original Dana/Spicer PTO, Dana/Spicer bought out by Chelsea, Chelsea bought out by Parker. The PTO appears to be an “R” Series, one speed forward/one speed reverse, Model RNC7-14, if the output shaft is 1-1/4 dia. The adaptor gear assembly is probably an original Dana/Spicer but could be a Chelsea adaptor, and Chelsea only offer 22- and 35-degree adapters. According to their 1970 catalog for the SM420, the numbers for assemblies are; 328031X, 328034X (filler block 7A-1250). You could contact Parker tech line at 888-744-8785 and speak with a rep. Some reps are familiar with the old Dana/Spicer PTO others aren’t so you could get someone only familiar with Parker numbers. Your PTO is missing the cotter pins that secure the gear shafts, part# 500026-11 and if you haven’t put something in the shaft pin holes you need to. Slots in the end of the shafts allow turning to align the shafts with the hole to allow insertion of the pins. I have attached a copy of mine I am rebuilding for your info. A new model# 352XSBJX-Y5XDX (62% of engine forward, 80% of engine speed in reverse is available from Parker for the SM420 if anyone is interested.
