SM 420 advice again
I recently rebuilt an SM420 and put it in my 73 fj40, I have maybe 500 miles on it and I'm having a couple of problems, It shifts great etc no vibrations, but when it starts cold it has a howl, not just the normal howl, when I make harder left turns if makes more noise even rattles a little like something is shifting around, and shifting to the passenger side of the tranny when I turn, any advice before I take the top off and have a look, anything I might have left out or not taken care of? thanks, Larry
Theo, Yea I put a whole new clutch in, I think Pin Head is right I think I'll just rock and roll, you can buy them here for 75 bucks so If it craps I'll get another, thanks again, Larry
Hi All:
Larry, what weight of gear oil are you using in this SM420? Did you replace the seals when installing it?
I usually don't suggest synthentic gear oil on older gearboxes (because of leaks), but I have found that it works *really well* on newer gearboxes!
I'm assuming that your SM420 is not getting enough lubrication right at the beginning, until the dino gear oil warms-up and flows better.
Good luck!
alan
Yes I replaced all the bearings and seals, I'm running 90 weight but at 10 degrees in the morning it's always stiff, Larry
I know the sm465 has sintered iron sleeves on the mainshaft for the gears to slide on. If the 420 has them maybe yours are worn.
