Slowwww Wipers!
Always on the Run
What is the fix for super slow wipers? I have 3 speed wiper (Intermitent, slow, and fast) there is no diff between slow and fast, it is just slow. Does the motor need rebuilding if it is even possible? or is it my switch?
Roberto
Cool. I have one-speed on my FJ45, 2 speeds on my FJ40. What model and year are you talking about?
There's lots of info on here about slow wipers. Most tear apart the motor, clean it up and put it back together. You could need new brushes, also. Do a search like this one - https://forum.ih8mud.com/search.php?searchid=1500495. I put "slow wipers" in the search box and that is what I came up with.
Good luck!
This is from a previous post of mine. I don't know for sure that this applies directly to the wiper motor from a BJ42, but it probably does. The 12V and 24V wiper motors might be the same, but I don't have any experience with 24V LCs.
[In addition to cleaning it, you may need to replace the brushes.
You can order tool brushes here: http://www.graphitestore.com/_ p/n 10-181811 (Carbon Brush 0.187" x 0.187" x 0.625", H3). You'll need three of them. Cut the copper plates off of the new brush pigtails, sand them down on one side to fit the brush holders of the wiper motor, and solder them in. You may even need to sand them down a little in length to get them into position. Radius them to the commutator as best you can. Be careful and take your time. The motor will function like new after replacement of the brushes.]
I need 3 brushes because it is three speeds?
Yep, you need 3 brushes. High speed brush (+), low speed brush (+), and the (-) brush that is common to both speeds.
When I bought brushes last, you could order them individually. I believe they now make you buy eight brushes. You'll have some spares in case you damage any during the installation. You could also share some with a friend.
One thing I should add: When you cut the copper plate off of the new brush pigtails, cut as close to the copper plate as you can. You need all of that wire length to make the connections and allow the brushes to advance properly in the brushholder.
Correction: Now they're making you buy 12 brushes. Definitely share them with a friend. I'm sure you can find some new friends here on mud that need new wiper motor brushes.
A little tipo on holding the brushes back while sliding the rod is to use small zip ties slid in between the brush and the metal piece that holds the brush then pull the zip ties out once the housing is slid all the way down into place.
