Slow sticky windows
HEY GUYS,my windows are moving pretty slow,im guessing the seals around the windows are sticky,i pulled the door panels off and cleaned the seals with soap and water and this helped a little,my cousin suggested using axle grease (apply with a qtip),he said he has done this many times with good success.any body have any suggestions?i just hate to put grease in the window seals to later find out there is something better,replaceing the seals i feel would be beyond my budget.thanks
Use some silicon spray along the rubber runners. It helps some. I also tried spray lithium grease on the mechanism inside the door and this also seemed to help a little. They are still slower than new. If I am parked I will rev the engine to about 1000rpm and they will move faster.
There are also plenty of posts with regard to this as it seems to be a common problem with these vehicles search around and check out other ideas also.
Many have replaced the window runs with good results. I plan to do the same soon enough...
what about replacing the window regulator? (the metal arm scissor thing)
thanks guys,my issue is definetly from the slides being sticky,they were so sticky b4 i cleaned them that the scissors pulled away from the glass and it was not easy to slide the glass up and down,ill try the silicone spray this evening and report back thanks guys.
all it's about V available at the window motor .. and the windown runs .. clean all your window switches and check the V at the motor ..
Talk to my VW without those features LOL :flipoff2:
Little silicone or grease on the scissor lifts can help alot ! :D
But seriously I do agree you do need good juice to your motors.
what does this mean : "all it's about V available at the window motor ......"?
if you install a V meter .. you will see when you are up your windows your V will raise a bit .. due to the lower amps .. ( that really needs the window motor )
This past winter, when I would roll the drivers window down it would get stuck in the rubber runner and pull out of the bottom support (scissors).
I pulled the glass completely out to check everything. I noticed that the rubber runners had almost swollen shut in the bottom half of the door. I assume the rubber had swollen because 99% of the time the window is up and the lower half had expanded because there was no window there to hold its shape.
The rubber seal was clamping on the window and not letting it go all the way down. This was after lubing several times over the years (which may have caused the swelling in the first place). My no cost solution was to cut away some of the rubber seal to release the pressure the seal was causing. This worked for me. My window has not pulled off track since then. It is also goes up and down a lot quicker than before.
This may or may not work for you. I would check it out before buying new seals though. The next time the window pulls out of the lower support, look at the rubber seal where the window frame meets the door and the gap in the seal will be obviously different. Also, the seal was noticeably harder in the lower section.
This may only be a band-aid fix, but as I said it was free and works for now.
Your issue is probably a combination of all the things mentioned in this thread.
