Slipping clutch/adj?
palisade,co
Have a modified 1972 FJ40. Has 2f and four speed. Was out at Moab today (nice weather) and when I hit power felt the clutch slipping. If I jumped on it, it would jump 200-500 rpm until I backed off.
PO said new clutch 8k miles ago. Yes they all say a lot. Don’t know much at all about Hydrulic cloths and the systems. Don’t know if adjusted issues , a bad seal leaking oil or other issues.
Suggestions of adjustment, what to look at with the hydraulic system. All ideas will be appreciated.
Slave cylinder down at the Trans. Loosen the locking nut and then back off the cone nut until you have some play in the clutch fork.
When you take your foot off the clutch pedal the clutch fork at the Trans should have a little play in the slave cylinder rod so you aren't riding the clutch so to speak. Hopefully I am explaining good enough.
Thanks very kind of you. Just an example of the folks here.
Does your clutch disc disengage as soon as you start to press on the pedal, or more like halfway?
Oh Mark you are a physic yes about 1 inch and it releases.
Ok, then you should definitely follow the advice of @JAFO2014 and loosen the slave. But now it’s got me wondering if the master is new?
It’s dark outside and 6 am went and looked.
This has a 1986 FJ60 4 speed. The clynder has a boot and then 1 inch of rod into the cloth fork. ( if I am right). No cone or lock nut.
So now with this data. Is there other adjestment points? Clutch pedal?
Thanks so much for all the help, it is kind of all.
Ok read more. The clutch pedal is low 4.25 inches. Now where near the stop.
So plan to loose stop nut screw out the shaft. Hope to get 7.13 inches.
Yes I will tighten the stop nut when done.
So went to work on the pedal adjustment. Raised my pedal height and it seems to be fixed!
Just keep reading threads it has happened before!
Good to read this Scott. Had I been your installer, I would have recommended installing the earlier fork that takes the adjustable slave when that engine was put in. I never have liked that non-adjustable slave.
Well if I ever pull it apart I will follow your recommendation. In he next year we will be clearing out my mom’s estate. Will have a UHaul and plan on stopping to buy parts when in Mecca.
Thanks as always.
