Slip joints or yokes help?
Richmond, VA
How much in and out movement should I expect to see from the slip joints on the drive shafts.
I greased them recently and then read about hydrolocking.
I put a zip tie on each shaft to see how much they move, and they do seem to be moving slightly.
Do I need to worry about anything?
Due to the linked suspension, the splines move very little. In normal street driving there is hardly any movement, there is a little more when flexed, off-road. If you worried that you over filled, unscrew the grease zerk/fitting and see if any grease is expelled.
At least one mud-ite did have damage he believed was from over-lubing the driveshaft and driving on the street. He's usually not wrong about things Land Cruiser.
I guess some movement is better than no movement.
Does grease come out of your slip joint after greasing it?
Because mine does not.
I seriously doubt it. On Toyota trucks where hydro locking is a possibility they vent the tube. One case is the leaf sprung Tacoma and the rear drive shaft has a vent hole in the end of the shaft inside the yoke for the u-joint.
So bascally I need to take out the shafts and clean out the slip joints and regrease and install.
How long does something like this take?
if i were you i would unbolt the shaft from the differential and pull the shaft leaving it attached to the t-case (4 less bolts to remove) apart easy enough to clean the splines from under the truck. As for how long it will take maybe 30 min maybe an hour depends if the grease is caked on or not.
remember when you put the shaft back on to make sure the u joints are in faze
Should I mark the shaft and the diff before I remove so as to put it back in the right place?
A dumb question what is u joints in phase?
Yes, you should mark the shaft so you can put it together the same way. If not, you may throw off the balance.
-Spike
Eventuality, if they haven't been greased in a while it takes some miles for it to work out to the seal. Mine have a slight ring of grease around the seal area. My grease plan is 4 pumps in the spline zerk each time the shafts are greased.
How much did you put in? My first test would be to remove the zerk and see if grease squirts out.
I do the clean and hand grease thing when the shaft(s) are out for other maintenance, IMHO the best way to do it, also the best way to judge the condition of the joints. If your going to remove the shafts, you only really need to drop the spine ends. Be sure to mark all of the parts, so they can be reassembled in the relationship. Properly torque the fasteners, having the hardware come loose will cause expensive damage.
I put just enough grease to get a slight movement and thats it. The zip ties I put on the shafts to check movement did move about 1/4 to 1/2 inch or so after flexing the suspension. The rig is new to me and the slip joints do not look like they have been greased to often. I will give it a liitle bit of time to see if the grease works its way out a little.
