Well I flushed the radiator and coolant this afternoon. The coolant was pretty clean (not dirty and very little silvery flakes). The last time I flushed was last spring when I put in a new radiator, water pump, all new radiator hoses, thermostat, and new fan clutch. I re-filled with Toyota Red of course.
However, it seems that my coolant temps are running a few degrees higher after flushing and topping off. Any ideas guys? I checked for leaks and couldn't find any. Replaced all the heater hoses including the PHH about 18 mos ago also.
I may be overly sensitive but it seems that the temps should go up after the coolant change especially if it's now cooler out at night when I test drove the vehicle post flushing.
Thanks in advance.
Thanks in advance.
