1997 LX450
121K miles
I have a slight miss at idle. This seems to be the only point where the miss is noticeable. The engine is smooth at RPM’s above idle and my fuel economy is right on target. All the tune-up items have been changed with Toyota parts minus the fuel filter and O2 sensors. I’ve also changed all the vacuum lines on top of the engine including the PCV valve, grommet and hose. I’ve put BG44K through the gas tank a few times but it had no effect on the idle miss.
Does anyone have an idea as too what might be causing by problem?
121K miles
) I can tell there are situations where my cooling system is saturated and cannot sufficiently dissipate heat... the factory gauge's dead spot hid this behavior though. Perhaps it is normal, but there is nothing wrong with lower under-hood temps!
