Sliders Info. Needed
State of Flux...
What's the 'low-down' on the following (4) side rails / sliders options?
  • Hannah Sliders
  • Slee Sliders
  • ARB Side Rails
  • Custom Fabricated
Can / do the ARB's serve as moderate sliders? Any / all info. is appreciated as I'm tired of 'pounding' my stock running boards back in shape after wheelin'...
Thanks man...that pretty much nixes the ARB's. After further review, IMO, I think I'll get the most 'bang-for-my-buck' with the Hannah sliders...and, I just like'em.
Ditto on the metal tech. they some sweet sliders that protect the exhaust along with the rocker panels. They are more expensive than all the others, but what does and a new exhaust and rocker panels cost?
The Hanna sliders I have protect the cats, but the rest of the exhaust is un-protected.
I just went through all the research and decieded on the Metal Tech sliders, The extra protection was worth to me and the guys at Metal Tech were great to wrok with. They are expensive, but after talking to them, it is their least profitable item. The powder coat inside and out was also a plus, in SLC we use alot of salt on the road and i didnt want them rusting any time soon.
Good luck with yours.
What about Irbis/Solid Rock, great pricing anybody running them?
I have Solid Rocks sliders and I love them so far. I have not tested them yet but will be going to the round up to test them. Good prices to. good cat protection to nice and beefy
Angelo
I have a set of sliders from Irbis, and really like them. Irbis and Solid rock can make sliders custom, the way you want them. I think it is a good idea to support some of the smaller companies so there are more options out there for everyone.
I have the Slee step sliders and love them. Yes they are a bit expensive but my wife is happy because she can load the kids in the car safely and I'm super happy because I've got some stout sliders.
Thanks for all the info. Does anbody have dimensions & specs / instructions on how to fabricate sliders similar to all of these...I'd be interested in taking to a local welder / fabricator and seeing what they'd charge to mfg a pair...Thanks
I was thinking the same thing, but when you add up your time, the cost of welding, powder coating and all the frustration of fitting, i would recommend buying some. for me, it was not worth the frustration. just my humble opinion.
68" long main rail
4" rear out rigger
9" center outrigger (depending on the year) ;)
where you place them will just depend.
the front of mine are custome so you're on your oun on that one ;)
i cut my 1.5"outer tubes at 75" from center i measure 24" out, start my bent there and bend each end to 70 degrees.
from there your options on the outer tube set up is endless.
angled,flat, and plate the top for a step.
cat protection is custome also :D
hope that helps
Solid Rock Off Road
My SROR slider, with step plates, were finished today - and Jim even found someone to take them down to the Lone Star Cruiser Round Up event this week for me! They look great in photos and I can't wait to get them on. If anyone who is going to be at Katemacy wants to check them out feel free.
Just now seeing this thread, sorry I was at the Loan Star Round Up when this was posted. (or could have been on the road it did take 3 days just to get there!)
It took me just over two years to completely develop the Metal-tech sliders and could have bought another 80 for the hard development costs. What sets what we make apart it is the combination of several key features.
+ Our cat guard is laser cut and CNC formed out of one solid piece of ½ inch plate. The guard is open to allow the cat to cool correctly and not trap debris. (Also keeps the weight down)
+ The rub rail has a second stage to help push your truck away from an obstacle to help save your quarter panel.
+ The three mounts to the frame on each side are spaced evenly.
+ Not one piece of steel is off the rack, it’s completely laser cut and formed. The main body is contoured to match the side of the 80, not off the rack box tube.
+ Accessories mount off the driver’s side for an air tank or extra battery
+ Powder coated on the inside as well as the outside.
Metal-tech is in its 6th year building parts and supporting 100% only Landcruisers. From the first year have supported the TLCA and most TLCA events. I do this full time, this is what I do. MT has 2 employees full time, LT and myself. If being professional sets us apart from being “small” I will take the professional stamp.
I wish I could spend more time on the forums like I used to but the demands of a small business exceed my time. I keep telling myself “I will not go back to the cubical!” then I suck it up and focus on what needs to be done.
Mark
I am always one for building my own gear, this is how MT came about in my garage 7 years ago.
As for building your own, Gorges plans have been around for years. Lots of home built sliders have come from these. I think they are over on Morgan’s server birfield.com . Speaking from experience! If you do the work yourself and don’t factor in that cost you can do it for less than buying a set. Now if you pay a quality fabricator to build them AND have them properly powder coated, well over $1k easy.
Powder Coating sliders:
Factor in this cost if the sliders you are looking at are not powder coated. To pre bake, sandblast, dip and double powder coat a set of sliders will cost $200-300 for one set. Call around to powder coaters in your area. (Use 72” x 24” x 12” for size and aprox 70 lbs each for the quotes)
Alternatives;
Rattle can, you get want you pay for there. Easy to touch up but plan on complete recoats to keep it looking nice. (fade etc.)
Epoxy finish: Hammerite, POR15 etc. Look at the cost of materials. $100+ paint alone. To prep, best is to sand blast cost there is upwards of $100 if you find a cheep place. Again it’s back to sandpaper and your time to do the work. I have shipped one set of raw sliders and the customer later said he wished he just got them powder coated by the time he was done epoxy coating the sliders.
Mark
Mark
those are sick mark!!
:cheers:
