Sliders/air tanks
Brigham Utah
I am going to install an on board air pump and was thinking instead of a separate air tank just building my sliders as the air storage tanks that way there would be air to both sides to make it easier to air up plus run air tools from either side for changing wheels etc plus I think there would be just as much volume as the tanks I got from a small scrap compressor if not more thoughts pro or con ?
T
I made a set of sliders for a friend with fittings to use as air tanks. The sliders used 4x2 rectangular steel. The volume isn't as great as your would visually think, maybe around 3 gallons for both. You would need a bung to at least occasionally drain condensation out.
I didn't bother doing that with the sliders I made for myself. I just bought a tank and installed it under my m12000 winch in my ARB. It tucks up tight and is about 18"L and 6" diameter. Total volume is 2 gallons:
I just put an airfitting on the bar and with some hose can reach all 4 tyres and the spare on the rear easily. I store the hose in front of the main battery (polyurethane coiled hose).
cheers,
george.
