Slee Slider Install
retrofive
rɛtrəʊ
swfl
Ok this is an easy question. Ive searched but didnt finid exactly the right answer.
On the 93-94 frame the brake lines run down inner driver side part of the frame. For those of you that have install did you remove the brackets? just bend the lines? They seem really snug to frame and didn't want to damage them went getting the unbolts under the lines. Those bracket bolts are PITA to get to.
On my sliders (with u-bolts) I put 'spacers' under the brackets to space the brackets/lines out from the chassis to allow them to go on the outside of the u-bolts without rubbing on them.
cheers,
george.
Thanks MoJ & G
I feel dumb, that seems like a very simple way take care of it :D
Im uno :banana:, didn't want to muck up my brake lines.
Typical me over thinking a simple solutions. :cheers:
thank you.
Thanks. My first attempt yeilded at not being able to break free the middle brake line bolt this weekend. Got some PB blaster on it, we'll see tonight if it will play nicer.
I just bent my brake line brackets out too.
