SLEE rear bumper question
miami, fl
how do you fasten the high lift jack to the bumper? there is a bolt in the back of the tire carrier. is it supposed to go through one of the holes on the high lift?
thanks for the help
There is a saddle on top of the swing arm that the jack base rests on. The tire carrier hoop has a U shaped channel with a stud in it. The jack "rail" goes in the channel with the handle on the top side. and a plate goes over the channel, secured by a nut.
hi cruiser dan. thanks for the info. so the bolt IS supposed to go through one of the holes in the lifting bar?
mine doesn't have a channel as you describe(different design?) but it does have the bolt. the problem is when i put the jack on the base of the bumper, the bolt does not line up with the hole on the lifting bar. if i lift it to line up with the hole, the base slides out from the bottom.
