Depends, if its a 3 pin winch control or 5 pin (8274-50 for example), I believe the 5 pin controls the ground connectiion to the solenoids as a safety to prevent both sets of solenoids from engaging at the same time (BANG)
All your doing with a 3 pin is running power + to either one set of solenoids (in) or another (out)
Edit: and a ground for lighting of the switch...
Sorry it should work on all winches. Although you might have to fi-nagle abit.
I used Slee's diagram to wire my winch controls a few years ago. It's really nice to have.
One thing of note is that if you use a 4Runner antenna switch (like I did), it is a momentary toggle.
It's impossible to push both buttons at once. The DPDT relays are not needed.
I didn't know at the time and just used DPDT relays- but I guess it's cheap insurance.
If you use the LC antenna switch, you need DPDT relays to protect from pushing both buttons at the same time.
Sorry for bringing up this old post, but I have a Warn Zeon Winch and need to find what wire to connect to a relay in order for it to bypass my Redarc Isolator.
Warn does not want to tell me this, and refers to my local auto sparky, and they in turn refer to the Swedish Warn distributor. The distributors auto sparky says I should measure it up.... Catch 22 anyone?
I'll attach the Redarc wiring diagram for reference, and to clarify I need to know if someone knows what wire to tap in the Warn Zeon control box?
