So last Saturday I had an unexpected spare hour at home. I decided to throw the arms on the crusier to see what would happen. Front getting out the tools to putting them up, I spent about 55 mins on the swap. It was pretty easy and I was happy. Once I had the OEM arms off, I laid one onto of the slee arm to notice that the Slee arm was about 1'' longer than the stock arm. I didn't think much of it and went ahead and put the slee arms on.
One the test drive two things were very obvious:
1. The steering was heavier, but much more comfortable and with a little too much caster, I was happy.
2. The front driveshaft was not happy at its new angle. I had a drive line grind/vibe everytime I would let off the accelerator. I would also notice the same noise/vibe at some points while giving or keeping throttle.
Move ahead to tonight where I decided to swap the stock arms back on and wait for time to get a 2001 Tacoma drive shaft to fab up a DC shaft for these arms. Luckily my caster is not aweful with the stock arms (.3 and .7). I can live with it until the next phase of the build.
Well tonight was a PITA! That one inch that the axle had moved forward for the slee arms was a B!T%# to get back and line up the stock arms. After about two and a half hours, I finally cleaned up my tools and took a shower. I had to get creative with jack stands, floor jack, and 3 different punches. I finally got it buttoned back up and now I am back to square one. At least I know that I will like the caster with these arms installed. I just need to plan to have the drive shaft before installing these arms next time.
Next week brings new tires, bump stop drop block install and maybe rear brake pads if I have time. Then I will also need to find time for the extended brake lines that CDan has on a truck coming to see me. This journey never ends.
Smit
