Slee Blues Installed
Nay
Colorado
I had the Slee blue caster correction bushings installed yesterday using Landtank's template. The shop got them identical side to side for $53 (Predator 4wd in Colorado Springs).
My OME bushings upon removal were clearly in poor shape from rock crawling use showing wear around the sleeve. The front end is simply tighter from the new bushings. Handing is definitely improved. I am not noticing much in a straight line on the freeway, but the motion of entering and exiting a turn is tighter and doesn't require incremental corrections.
I have no vibes at first freeway test up to 75 mph (spinning at 2,900 RPM on 5.29's). Maybe a tiny decel vibe from 65-60, but I'm probably listening for that one. It should vibe, the angle differences in u-joints are ridiculous, but then it shouldn't have worked with the OME bushings.
Bottom line - it's a nice improvement and worth $200 if you stay vibe free. If I could run OME correction without vibes vs. Slee blues with vibes, I'd run OME if I couldn't afford the plates/DC route.
It's pretty obvious that my draglink and/or tierod could use a refresh on tierod ends, so that is probably next on the list, and I finally bit the bullet and bought a MAF 4+ adjustable front panhard since I could see the arms were off side to side remounting them by about 1/2" - I figured now was the time to prevent any incremental wear and tear from that shift even if it hadn't really be noticeable visually. Simply having zero mile components vs. 120K miles components in the steering and suspension is a really nice upgrade.
Hats off to Landtank for the template - it let me drop off the arms and pick them up a hour later for $50 with perfectly aligned bushings. :cheers:
Don't be surprised if those decel vibes start getting worse. I only had a hint of a vibe on decel at around 30mph, now it has spread across a wider mph range after 2k miles. I want to try and put new u joints in the front shaft and see if that fixes it.
I have 3.5" of lift as well with the blues and no vibes. I didn't expect Nay to have any.
We'll see. I'll probably just do the "washer mod" for the bit of extra adjustment I need and a DC shaft if I end up with vibes and keep the blues in there.
I am using the slee CC plates,no vibes at all-super smooth.For years I was runng the OME 2.5" hds w/no castor correction.Man I had alot of problems(vibes) should have put in the OME cc bushings when I did that lift.
Are the blues only for the 3.5" lift? Does Landtank have a website or do you just PM him?
You can PM Landtank for the template. The blue bushings are sold by Slee and provide a fixed amount of caster correction (more than the OME due to the offset eye in the sleeve).
I do have pretty good decel vibes. It's too much to leave alone. On the bright side of things, I may have enough correction to just run a DC shaft - I need to go measure, but visually it looks maybe a hair high but what should still be within DC specs. I'll report back the numbers.
This has nothing to do with LT's template, it's just angle misalignment.
I'm posting this largely for the sake of archiving. I pulled out the gravity protracter to measure my u-joint angles to see if the Slee blue bushings corrected enough for a DC shaft. Even with OME CC bushings I was only about 2 degrees off, so I thought it would be close.
Using a socket to extend the u-joint cap for angle measuring, I hit 7 degrees exactly for both the driveshaft and u-joint. In other words, it's lined up for a DC. I'm going to double check tomorrow just to make sure, but visually it sure does confirm. That means I can do a DC without needing plates.
I'm going to try and source a local DC Tacoma shaft and have my driveline shop modify the length and rebalance and see if I can get away with it for about $150.
Bummer I got vibes, but it's no surprise. The stock shaft angles are off by at least 7 degrees. It's amazing it is even driveable.
Are you sure you used the correct u-joint cap when you did this? I prefer to compare two adjacent caps verses a cap and the shaft itself. It's a little more work but gives better results.
I did it both ways. 7 degrees on both adjacent caps and driveshaft.
I have to say, I wonder about my lift measurements with no flares, which are 23.75" center of hub to fender. I was wheeling with an 80 owner yesterday who has the Slee 4", and with 2" bumpstop drops like I have he must have at least 1.5" more axle tube to bumpstop distance than me. In any case, the blue bushings are correcting pinion angle for me, although I will remeasure tomorrow. It could be that my rig is an oddball, but that would be lucky for me :D.
