Slee 1" Spring Spacers?
California (Corona, Irvine, Anaheim)
Are these supposed to be installed directly above or directly below the front springs? Thanks!
Bottom left blue spacers here: http://www.sleeoffroad.com/products/suspension_pieces_spacers.htm
1" Front Spring Spacers
Part#:SOF1077 - $35.00 /pr
Fits 91-97 Land Cruiser
These polyester spacers can be used to add lift to the front suspenion of the 80 Series Land Cruiser.
I have these and they fit great. Install took about a half hour. Just disconect sway bay and shock, push down on one wheel while other is supported and the springs come right out. They are a little tougher to get back in but it's a pretty easy install.
I got them too and really like them.
They go on top of the spring. Like Cmadness says, it takes like half an hour to install.
Regards
Alvaro
I got them too...
With OME J and the slee spacer... Now my Land Cruiser it's straight...
sorry for the hijack...but does anyone think that the OME 850/860 lift will require anything more than the Slee 1" front coil spacers to re-lift my rig to level with a new ARB & Warn M12000? My ARB arrives on Monday and my used M12000 will be here any minute...Thanks
Tx80- Im Running The Same Spring Combo As You And Im Also Runnin The Arb With A Winch. I Think Youll Be Right On The Money With The 1" Spacers. The Way My Rig Is Set Up, I Still Have A Slight Rake Which I Dont Mind, Since I Sit Level When Loaded Up With Gear For Camping.
Is it possible / recommended to use the Slee 1" spacers with the MAF 10mm trim packers as well? This would give me approx. 1.5" of front-end lift. Do you think it would have negative side-effects?
On the front you'll loose about 2.5* of caster. Depending on where you are now that might render the truck un-driveable or at least a thrill to be sure.
I have the Slee caster correction bushings already installed and the truck drives great with my OME 850/860's. I'm installing the ARB + M12000 next week and want to recover any potential front end sag from the added weight. I guess I'll just have to wait and see what the new equipment does then adjust accordingly. Thanks
