Skool me on York's
Montgomery Co. TEXAS
Website
missionsonwheels.org
I've got no expierence with York compressors. I'm looking to install one on my '98 5.7 Vortec using Medusa's write-up. Is there a model more desirable? Does anyone make brackets for the Vortec's. Any models to avoid?
Thanks,
Mike
Contact the guys from Northwestfab they may be able to help you out with brackets. Most of the bigger issues your gonna run into are the pulleys. The clutch that engages on the older ones is HUGE. For the money and time its easier to grab a VIAIR 400/450.
To help you out a little more my 1998 GM FSM on a/c says min pressure on high side is 160psi. Couldnt tell you what CFM it can produce.....
The 210 york is the largest and you want the long stoke model as it puts the cfm's out there are ways to tell the models a part alot of infromation out there mostly about heeps. Other a/c units work maybe one would be a better fit but have never really looked at any of those setups. Yorks use v belts so maybe you get a double split pulley for your altenator one for the sepitine belt and one for the york v belt and maybe kirby makes a different pulley for the york
Consider the "super compact" SC209 model. It has 9 cubic inches displacement (instead of 10 for the 210) and it is about an inch lower and an inch narrower. It is found on mid 80s VW Cabriolets.
Thanks Pin! I know height will be an issue according to Jack's write-up. It'll feed into a tank and should keep up with my needs for it..... which are fairly limited.
Mike
