Skid Plate Options
Frazier Park Ca
Hello all, I Just replaced my transfer case with a rebuilt unit I bought from member here on this forum, thanks again Ross @Rock40. Question I have is on adding a skid plate to protect my new case and parking brake assembly. I can’t use a stock plate as I have a 350 with Toyota 4 speed with 3 speed tcase and it won’t work. I,m looking at the Iron Pig FJ40 skid plate that looks like it will work nicely, and I understand Downey plate may be available? My junk hangs below my frame about 3” and the IP plate is 3.75 deep according to IP. Maybe someone has one they would like to get rid of?
I am out of stock on my H.D. skid plates, and have to question if I will build more- - -takes way too long to sell a batch, ties up $$$ for way too long. Know that it is very typical to "space down" the skid plate on Chevota conversions, lots of guys use a stock skid plate, and merely add spacer plates or tubes between frame and skid plate.
I run an Iron Pig skid plate. You can redial to adjust the locatoon. Works great.
Hoping maybe you had one. Been there on the spacing of stocker but cut mine up for sucky exhaust early on and would need a lot of spacer to work. Thanks for reply.
I have no problem running stock thickness skid plates. The few times I ended up bending them was bashing the bottom on rocks which I grew tired of quickly. So would also depend on how you plan to use it. When I switched my 68 to a four speed I didn't have the room to really work on it and just reused the three speed skid plate. Next time I pull the transmission will modify the mounting on a stock four speed skid plate. When I install a five speed in my 79 FJ40 will use the correct crossmember and skid plate. Unless I use a 8/80+ frame it will require some modifying since rivets and fixed nuts changed location after the 80 model year. Figure a $100 for a stock five speed skid plate was cheaper than anything aftermarket and would be plenty strong for me.
Iron Pig skid plate on mine also. Very heavy duty.
Well I decided on the Iron Pig skid plate and installed it yesterday. I took a couple of pics in case anyone else is interested. The IP Skid plate is very well made and has the protection where needed and is not straight across like the stocker but tapers down by TC. FYI, I found two stock plates on Ebay, restored (repainted) and they were 300 bucks each and would need spacers to work. Same price as a well designed and much stronger IP plate, no brainer for me. Fitment was right on and bolted to existing frame holes. I had to drill out 2 additional holes but found my 71 frame had x marks where the holes needed to go, nice. Now I’m ready to go back to Rubicon Springs this summer.
Very nice! Might I inquire what the shipping on that little beast was???
BTW: Used to roam around FP and Gorman back in the 80's with my 80' Hilux 4x4...lots of sweet memories on the Miller Jeep Trail!!
:cheers:
:cheers:
It was about 40 bucks for shipping. Interesting packaging, they just put a sticker on it and toss it in the brown van lol. It’s 45 pounds and has about a 4” drop at TC. Still waiting for the forest to open up here from winter closures ( yeah they didn’t do that before) hopefully May 1st, locked gates nowadays.
