Single stage rattlecan paint
Spook50
Skål
Supporting Vendor
Spokane, WA
This summer after the rust repair (priority) I want to pull my windshield so I can replace the gasket with a lock strip style (using the WagonGear rubber lock strip) gasket, but while it's off I want to strip my gutter, fix the surface rust, remove the body filler/sealer, seal and repaint. Current plan is to repaint the whole roof white using a couple cans of single stage paint from here: http://www.66autocolor.com/White_Single_Stage_Paint_p/ss-wa9753.htm and to find a company that'll make single stage paint color matched to the factory code for my 62 for going over the rust repair areas and spots where the clearcoat has oxidized. The company I linked has the white paint, but I can't find anywhere (online anyway) that makes single stage paint in rattle cans (which I'll have to do for the color code match). Any of you guys know of a reputable company that will?
check your local jobber alot of paint stores that supply the automotive paint industry will do this. I live in a mid sized city and have two near me that will,you may check with your closest supply as shipping can get expensive on items like paint and solvents. You may be supprised what a local paint store can do.
NAPA just did some paint for me.
Got it in one day. Pricey though, 24/can which is about normal for color coded paint but way more than Rustoleum.
