Singing the precup blues
I don't have the B series FSM in front of me at the moment to check the specs. I know it shows the liners should be installed slightly above the block deck height. I think something like .003 inches maybe? It's an interference fit to clamp the fire ring on the head gasket. Maybe the MLS gaskets don't like this setup if the pre-cup isn't completely flat with the head? A composite or fiber gasket would have a little more give than an MLS gasket.
So, as this engine is a mark II , it did not originally come with liners, or fire rings, so am going to get the machine shop to deck the block, fire rings and all, and pray that the damage is not deep enough to affect piston protrusion. And that the liner is not cracked. And that the machine shop is happy to bore an engine with liners to 1st over size.
Then I use the correct head gasket MML ( or whatever) and it should be as it was made, just a little bigger in bore.
Can anyone fault my reasoning???
G
So I can say from experience that MLS gaskets are completely unforgiving of irregularities in the head and block. Looking at the defect in your block, personally I would get another block or have your block machined true which comes with its own problems. I would prefer to go for a different block as machining it means you need to make up that thickness some how with either machining the piston tops or a thicker head gasket which I don't think is readily available. I really feel that if you put a precup in there its not going to get clamped properly and this hammering will just continue. Remember you don't need a pristine engine block... just a block, although paying more for a running engine might be worth it even if its expensive. My 2c.
g
I hear you Boet, but machining is cheap here, and I have nothing to loose.
Looking and feeling and using a straight edge, the liner damage looks proud ( of the block), so I'll ask them to take the fire rings flush with the block, and then a ball hair further and see where we are from there.
On gaskets then, the mark II B's came out with MLS gaskets, AND its sister, the 11B uses the same standard gasket and has two thicker sizes, (all to do with direct injection stuff), so I may still be OK.
The liners also have a generous flange, which the gasket overlaps quite happily, but yes, it's all going to have to be flush and smooth, the pre-cups as well, me thinks.
G
Cool. I didn't know there were different thickness gaskets. That is a big plus. The liner should actually sit proud of the block....0.1mm max if I remember correctly. That's not to be confused with the tall part of the liner that creates the fire ring if you will, its the lower part of the liner that looks like it sits flush with the block but it actually need to sit proud a very small bit to improve crush in that area and creates a better HG seal. Are you reusing the cylinder liner or getting a new one? Without the liner protrusion and the fire ring your head gasket might not have as long a life expectancy to say the least. They do increase clamp force and protect the gasket from a lot of thermal stress. If you get the block decked see if they can preserve the fire ring to some degree and mschine the liner protrusion to be identical to the other liners. If they can run their machine slow it will also give you a smother finish on your block which will aid in MLS gasket seal as they don't like rough finishes. Sort of like a dull mirror finish is the RA they like. I also used copper spray to help "fill" the machinng grooves which help a lot with oil and coolant leaks as they are low pressure leaks and don't propagate with a lot of force. Its what its designed for.
Permatex Copper Spray-A-Gasket High-Temp Sealant
There we go,11B on topand B below, but remember these will only work if you have the post 88 Mark II B ( no fire rings). These are MLS by tghe way, held down with TTY bolts.
I'm sure that the fire rings had (have) their place, but the more resent Toy diesels come with , no liners, no firerings and MLS gaskets, and I am not aware of ongoing HG problems.
Hopefully the nice wide flanges on my liners will fool the block and HG into thinking its standard once its all machined.
The block goes for her hair cut on Monday, I'll update accordingly.
OK, she is all back together, and my apologies for not documenting.
They decked the block , taking the fire rings flush any any damage done by the pre cup bits. By the time they had finished, you could still just see the rust marks made by those silly "holes that go nowhere" in the gasket, so not much metal at all. But it must have been decked before , because my engine serial number dissapeared and i had a bit of piston protrusion, sorted by using an 11B 1.7mm metal layer gasket.
Head got bent valves replaced, new precups and all skimmed flush.
So, it's now back to a markII B ( post 1985) but with liners except that:
I used "old style" head bolts, not the TTY's that it should have. I dont like TTY, but what are the rules here?
I used the pre 1985 B and 3B torque rating on the head bolts in the correct order, so i guess that this is OK even with metal gaskets, but should i re-tighten in , say 1000km time? or sooner perhaps.
Oh, and the gasket got a light copper grease smeering before going on.
I would apriciate any thoughts on the matter
G
I torqued my 12ht head after 1000 K and found the inner head bolts pulled 1/2 turn and the outer around 3/4 turn. The process I used was to back off half turn and then torque to factory specs. If you fitted a MLS gasket I don't think you need to retorque them.
I thought that mls wouldn't need a retorque too but I've done several and I always got a bit more from them. Since then I've been very diligent to meticulously clean the block threads and use torque lube cus I think my retorque was due to torque scatter from the bolt threads. Lots of rebuilders use taps to chase the block threads to clean off burrs. It wasn't the head not compressing, I was feeling the resistance from the threads. dirty threads = more resistance which doesn't translate to clamp pressure. Using rotational torque force to extrapolate clamp pressure can be misleading to say the least.
OK, will check it all when i do 500 to 1000 km oil change.
Not too sure about retorqing when HOT??? Why not when cold when the metal is shrunk, so that it gets tighter when hot??
Requested part numbers a few posts up Greg.
G
Ahh sorry that was confusing. I just start the engine and get it to temp then let it cool. Then I retorque. This lets the engine experience the expansion stresses and a lot of the bolt scatter will settle. I'm a bit paranoid of haveing small head gasket leaks initially that jet the gasket open and become larger. I prefer to be overly cautious and retorque early. Same with changing your oil. I do it after the first start/cool cycle to flush machining crap. No matter how cleanly you are there is always metal bits after doing work on the block. It's just oil so I consider it to be a little to no cost protective measure. It sucks to do a head gasket then redo it 500kms later. Some of my retorques would actually take more than half a full turn of the wrench. And that's with head bolts I could effortlessly thread in by hand feeling for burrs.
I edited my post. Sorry bout that. And I see the part numbers too.
Very cool.
Thanks
g
G
I'd expect it to work exactly the opposite. The head bolts will lengthen when they get hot. The coefficient of thermal expansion for steel is a little bit more than cast iron. (I have no idea what steel alloy the Toyota head bolts are made from.) This expansion could lessen the clamping force slightly because the steel head bolt expands/lengthens more than the cast iron head does.
Yep, happened to me. #6 cylinder pre cup dropped after only 50k, injectors done as well. Was going for rebuild but found a 2h with 300k so did engine swap my self. Cost was $1k for donor truck and 500 for misc parts and some help.
Sorry to hear, it is so heartbreaking to have major engine failure after a rebuild, no I did not do the cups at rebuild time
You guys have me worried now... I have a 3b with 480 000k on it never been opened. Now i feel like I should pull the head off before I'm stranded with a grenaded motor 800k from home!
@Gengis now that it’s been a few months how’s your custom motor job holding up? My cousins 3b 3000k after a full rebuild.
Side note anyone have any theory’s why all 4 pre cups are loose? Something was done wrong.
They were installed by a machine shop then the head was planed. Perhaps it should have been planed then had the pre cups installed?
Or I have heard they should be peened in place?
According to the machine shop the pre cups are the issue not the work they did, bad pre cups? They are going to be measured against the old ones and a brand new one.
