Simple 12v wiring question
Misery's feed trough
Simple for someone anyway. I am going to add a couple of 12v outlets in the back. One to power an Engel fridge and one spare. I have searched and found a lot of discussion but still have a couple of specific questions.
I plan to mount a distribution box with two 30-amp fuses in the rear 3rd row compartment. I will mount the receptacles in the removable door.
-Should I use 8 or 10 gauge wire from the front back to the distribution box?
-What gauge wire should I use from the box to the receptacle?
-Where should I mount a ground wire from the receptacle? Behind the panel there are a couple of screws that look to be for the flares. Can I ground to those?
30 amp is quit a bit of power. Other than a fridge, what are you trying to supply power to? Neither 8 or 10 gauge will be heavy enough IMO for a circuit that will see 30 amp worth of draw. FYI an 43 qt Engel fridge will only draw 2.7 amp when the compressor is running.
we have had a lot of discussion regarding this topic on the RS forum lately. Here is a link to my install, starts with post #28
Adding 12v accessory (cigarette) outlets - Page 3 - Rising Sun Member Forums
Edit: Sorry 8 gauge probably OK, I got my numbers confused again.
x2 on the approach Corbet used in the RS forum. The year-old install of the 12v aux circuits in my FZJ80 is very similar to his, including location for the fuse block, wire gauge sizes, etc. Except instead of the Blue Sea fuse block I used an ATO blade-type fuse block from WranglerNW.com (p/n 30-556-3/3 on pg 59 in their catalog) together with a 30A terminal block for the ground bus. This fuse block has two 1-in/3-out buses. On my set up, one bus is hot all the time and the other is hot only when the ignition key is in the ON or ACC position (controlled by a 30A relay).
I see the main advantage of this approach as flexibility and ease of expansion for future interior accessories. First time I ran wiring for an accessory on my FJ62 I thought I'd only be doing it once. Ten years later I had added all sorts of things as well as riping out some of the original stuff. It's a whole lot easier to do this if you've got a convenient fuse block to run power from.
I've also got one hot and one switched using a West Marine dual 12V plug. Put your fuse block in the engine bay as close as possible to the battery. Why do you want that long an unfused wire by putting the fuses back there?
Wrangler has great stuff but check with them first because I just found out that they have discontinued a bunch of their stuf
Here is the person I recommend speaking to over there. He made my life easier:
AmFor Electronics/
Wrangler NW Power Products
Stan Hackathorn
5061 N. Lagoon Ave
Portland, OR 97217
Phone: 503-235-4110 x 202
Fax: 503-517-0753
Wrangler NW - Power Products
I was going to fuse the wire by the battery, probably with a 100-amp fuse (saw that in other threads). I do like the idea of the 60-amp circuit breaker instead and will look into that.
From that I am going to run (probably 8-gauge) to the distribution block in back.
The only reason I mentioned 30-amps is because the distribution block I found locally has two 30-amp fuses. I probably won't run anything back there more than the Engel let alone something approaching 30-amps.
OK, I think I might run by West Marine tomorrow to buy some outlets & wire. To double check, if I run one 8-gauge hot wire from the battery to the distribution box in the back am I OK with using 10/2 AWG from the outlets to the distribution box? I would plan on grounding the individual outlets to those flare bolts in my pic. (unless someone tells me that will burn the truck up).
I am in the process of doing a dual battery setup. The washer bottle is relocated and my tray is in place. I have a National Luna system on order. I think the NL system has a 100-amp fuse that I can use inline on my 8-gauge hot wire from the battery to the distribution box in the rear.
The 6AWG or 8AWG from the battery to the fuse block *IS* fused. Corbet used a 60A breaker very near the battery; I used a 50A fuse in the same location.
"Cigarette lighter" style outlets are rated at 15A max and so should be fused with nothing greater than a 15A fuse. (Actually these are lousy style connectors - prone to loosening and overheating - but nevertheless still used by everyone/everything. There are better choices, but that discussion is a whole other thread.)
It would be best to use a separate fuse for the 8AWG hot lead to the fuse block, otherwise you are trying to use one fuse to protect two circuits. And although 8AWG wire can handle 100A for the 10 or 15 feet run you'll have, it'll get pretty hot at that current draw. You'll have an additional safety margin if you fuse the 8AWG with a 50-70A fuse or breaker.
The circuit breaker I used is available in 10 amp increments up to 150 amp. I really like it.
Downsize your fuses from 30 amp if you don't need that much power. Not only to protect your wiring but to protect what ever you have plugged into it.
As far a the 8 gauge wire someone else posted this chart on the RS forum as a guideline. I do not know its source or how accurate it is. Used it as such.
Wire Gauge Current Load in Amps @ 12 Volts DC
_________4A____ 6 A____ 8 A____10 A__ 12 A____ 15 A____ 20 A____ 50 A
20 AWG__ 26'___ 17'____ 13'
18 AWG__ 37'___ 25'____ 18'____ 15'_____ 12'
16 AWG__ 56'___ 37'____ 28'____ 22'_____ 18'_____ 14'
14 AWG__ 90'___ 60'____ 45'____ 36'_____ 30'_____ 24'_____ 18'
12 AWG__ 143'___95'____ 71'____ 57'_____ 47'_____ 38'_____ 28'
10 AWG__ 227'__ 155'___ 113'___ 90'_____ 75'_____ 60'_____ 45'
8 AWG___ 363'__ 241'___ 181'___ 145'____ 120'____ 96'_____ 72'______ 29'
6 AWG___ 585'__ 390'___ 292'___ 234'____ 194'____ 155'____ 117'_____ 46'
4 AWG___ 925'__ 616'___ 462'___ 370'____ 307'____ 246'____ 185'_____ 74'
2 AWG___ 1515'_ 1009'__ 757'___ 606'____ 503'____ 403'____ 303'_____ 121'
1 AWG___ 1923'_ 1280'__ 961'___ 769'____ 638'____ 511'____ 384'_____ 153'
0 AWG___ 2427'_ 1616'__ 1213'__ 970'____ 805'____ 645'____ 485'_____ 194'
I also used this resource American Wire Gauge table and AWG Electrical Current Load Limits to determine what wire to use.
Admittedly I'm sure I caused more brain damage than necessary for my install. But you don't want an electrical fire either.
Isn't there a sub amp back there? I would look there for a grounding location. The flare bolt is attached to a fiberglass flare and contact to the body is really incidental (it just wouldn't be MY first choice)
IMO 100 amp fuse is WAY to big for 8 AWG ... it should be around 50 amps to pop before the wire starts to burn.
I am going to go with a Blue Sea fuse block like yours as well as the 60-amp circuit breaker. I see that West Marine carries them.
It looks like with your installation you ran 6-gauge hot & ground wire to the fuse block and then individual 10 or 12 gauge hot & grounds to each outlet from the fuse box?
I think I will use 8-gauge and mount the fuse block in the engine compartment. I will run 10 gauge back to the outlets and a 10 or 15 amp fuse on each for now. I am going to use the Sealing locking receptacles and will swap the plug on the Engel for a locking one.
Yes I ran 6 awg from the battery to the fuse block. My intention was to minimize voltage drop as my HAM is wired into the fuse block rather than direct off the battery. I believe it took 11 feet to get there via my chosen route. Then 10 or 12 awg to other locations depending on distance and power needs. I purchased all my wire from this ebay vendor: eBay Store - marine electrical: marine wire, boat cable, marine grade . I've used them a few times now and I'm very happy with their service and pricing. Shipping is fast too.
Despite what others have experienced with the West Marine outlets I installed, I have not had problems with things rattling out of them yet. But if I were to do it again the locking ones are probably a better choice.
That's the first mod I do to my customers refrigerators when I add a rear socket to power their Engels but I use Marinco locking sockets !!!!!! :grinpimp:
Agreed on both points. Your 60am breaker is still too big. Drop down to 50amps if you are just running 2 outlets and 1 is a fridge. Step it up later if you need to.
Select another ground. Those flare bolts are prone to getting snapped off along with the flares (BTDT) and they are not a proper ground. Use the sub frame.
-B-
