side to side roll / swaying
Charlotte, NC
I just purchased my new rig and I have noticed that there is a lot of side to side swaying and roll when I hit large bumps or move the steering wheel side to side quickly. on a normal smooth road the ride seems fine. What should my plan of attack be to remove this. It is a 96 with 160k miles. it appears to be an all stock suspension.
I have a 95 LC with 310,000 miles and it is all original and it rides much better than the 96.
thanks for any help!
Shocks first, then sway bar bushings, and then just give the whole suspension a look-over for worn bushings.
yes check the suspension, and are your tires good? When i purchased mine i had the same issue but soon as I swapped the tires that went away.
I'd say tired coils are the main issue. If original and that many miles, sounds very much like our truck was before it got a set of nice, fresh OME 861/862. New shocks will help, but won't solve it. A simple swap to the new coils (nothing other than the coils is needed) is a fairly easy 1/2 day project (presuming you have adequate jack stands) and you can do the shocks, too, if you juice all the fasteners for a few days beforehand.
What greentruck said. Don't just do the shocks and not the coils. I did in two steps and wish I'd done both together. Shocks will help some, but the coils do sound tired and that's where I noticed a significant improvement. If you are considering a lift, mild or more, this is the time to do it since you should be replacing both shocks and coils at the same time. Steering dampener as well.
im getting something similar in mine. mine has a gobi rack and slee rear bumper so the extra weight is there. I do have airbags but seems like its a band aid fix. the best way I describe it is it feels like im riding on a rubber ball... ome 2.5" with medium springs, ome shocks...
